Results 1 to 14 of 14
    Jun 2014
    Hello mga katsikot! I have a newbie question, hope someone can enlighten me.
    Some reasons to save gas, is to have our aircon off, plus our car kicks more if the aircon is not on. But this put me to wonder if there will come a time that this may cause my car to overheat at some point due to high temp. Is my theory correct? or my radiator still produce "cool" water that circulates through out the whole car.
    TIA!!
    Your car engine actually runs cooler with a/c off. A/C off = less load on engine and less heat. If the a/c is turned on the a/c condenser actually puts out heat on the engine radiator since the condenser is in front of it. Your a/c does not cool your car's engine, sa loob lang ng cabin ang pinapalamig nyan.
    May 2010
    ^sa Focus S baliktad. When the ac is off, malapit sa 1/2 ang temp gauge ko. Pero when it is on, nasa gitna ng 1/4 at 1/2.
    Posted via Tsikot Mobile App
    different car models have different cooling fan configurations, meaning when the fan turns on.. what i have noticed on toyota Vios and and the new mirage cars.. is the cooling fans always turn on and off with the air compressor. while the fans on a Hyundai Gets is always on when the aircon is switched on regardless whether the aircon compressor is cycling on or off.. the electric fans on the Hyundai Getz thou are dual speed and will speed up if the temperature gets hotter.. i have seen Nissan cars that have overheated along the road goin to tagaytay because the main fans dont work when the aircon is switched off.. i think thought that has something to do with the wiring and maybe faulty relays.. some cars of course have dual fans.. and run indecently of each other.. meaning one fans is for the aircon condenser only and the other for the radiator.. the Hyundai Getz only has one fan.. i think the mirage also has one fan only..
    another thing i have noticed also on a hyundai starex GRX is that the auxiliary fans are always on when you turn the aircon on, the starex though has one belt driven fan and two aux fans,, that are also dual speed fans. the advantages i see in these configurations alone with the always on fan of the hyundai Getz is that, with the fans always on it doesn't give the condenser time to over heat, therefore not straining the cooling system of the car and the aircon system.
    i remember my old, 1970s toyota.. the aircon wouldn't get cold when in heavy traffic..
    my aircon man simply put in an aux fan, resulting in freezing cold aircon even in heavy traffic.
    Aug 2005
    Quote Originally Posted by SiRbossR View Post
    That's because the auxillary fan is switched on for the condenser. The added airflow gives your radiator more heat rejection.
    Jul 2013
    Sir do i have my AC UNIT be cleaned already if it behaves like this?
    Or its enough by just installing aux fan?
    Tnx..
    Quote Originally Posted by dj ian View Post
    Tnx..
    anong oto? may auxillary fan naman yan eh.
    ang magiging problema mo lang is kung sira ang auxillary fan or kung mabagal ang ikot.....
    Quote Originally Posted by Zac_espaņol View Post
    TIA!!
    on the assumption that your cooling system is ok, meaning, direcho ang daloy ng tubig sa radiator, ok ang thermostat, waterpump and sensors, it will not make your car overheat. nag kikick in kasi ang auxillary fan if the engine reaches a certain temperature so bababa ang temperature.
    you will only overheat if one of the cooling system components fail or if your radiator is clogged.
    gaya nga ng sinabi ko, yung auxillary fan mo should move properly, your water pump is ok, your thermostat opens and closes when needed and the temperature cooling sensor engages the auxillary fan if it reaches a certain temperature.
    imho.
    Apr 2013
    TIA!!
    as long as ayos naman ang makina mo, esp radiator and coolant level, don't worry.
    dito nga sa saudi, di hamak na mas mataas ang temp during summer (45deg ave)kumpara sa atin sa pinas...driving under the scorching sun is not a problem. recently i drove 3.5 straight hours (riyadh-dammam), 120-160kph speed, one time stop over (10mins), no overheating at all. my car is 1 year old.
    Jun 2014
    Thanks guys for the inputs. Btw, I recently had my car change all the liquids in my car, including ATF, oil, coolant. I decided to have my radiator be cleaned (overhaul), wala lang para lang isang gawaan nlg. Then drove it for around 30kms I think, and I found un water reservoir ko eh ngbbawas. Actually sabi ng mekaniko skn, need daw palitan un radiator cap dahil mejo manipis ndaw. Ito kaya un may culprit? pero kc prior ko pinalinis un radiator ko, hindi naman mxadong ngbbawas un sa reservoir ko.. will post picture here tomorrow.. nsa office pa kc ako
    Aug 2005
    TIA!!
    The radiator in theory can only cool until ambient temperature. But in cars, the optimal temperature range is anything from 85C-96C depending on the design and set fuel ratio.
    So effectively when calculating for engines, radiators are designed to have something like a temperature delta of 50C from ambient. Meaning, if ambient is 35C, the radiator must keep the engine at about 85-90C.
    So to add on to answering your question, if your engine runs any cooler, there will be a significant drop in efficiency due to lowered combustion rates. And even then your AC will not be any cooler than ambient nor will it be able to remove humidity.
    Oct 2014
    Mga Bossing sa Tsikot.com. Bago lang po ako dito. Meron po sana ako katanunga. Hindi ko po nabasa ang lahat ng Thread. So baka meron na pong kasagutan sa tanong ko. Meron po ako 2006 Nissan Urvan escapade. Ok naman po ang lahat except sa Overheating issue nya. Pag po running yung van ok naman po ang temp even naka on ang A/C. Pero po pag na traffic thats the time mag increase yung temp up to the point na papataying mo na ang a/c para hindi na tumaas. Kala ko Radiator proble kaya pinaoverhaul ko na pero the problem still pag traffic. Ano po kaya problema at magandang solution? I hope makatulungan nyo ako. Maraming ty po.
    Nov 2013
    ^check your rad fan. Baka faulty fan motor na yan, or faulty thermoswitch.
Cooling System Query
