Results 51 to 57 of 57
- Mar 2014
- 901
July 30th, 2015 11:54 PM #51Yes. Yun lang naman ang nire-read ng temp gauge natin na nasa instrumental panel. Yung temp ng water/coolant sa cooling system in every car through use of a thermostat sensor. To monitor and give us data reading if our vehicle cooling system is in normal operation during running our engine.
Sent from my UP+ using Tapatalk
- Jul 2012
- 329
August 1st, 2015 01:31 PM #52tried connecting bluetooth obd2 using torque app, hindi na detect honda jazz 05 ko. sayang, i was excited pa naman mgkaroon ng temp gauge.
- Mar 2007
- 9
May 3rd, 2017 11:23 AM #53mga sirs, may maadvise ba kayo na bilihan for a radiator fan for civic 2001? qc area.
- Mar 2014
- 901
May 29th, 2017 06:28 AM #55
- Mar 2014
- 901
May 29th, 2017 03:44 PM #56Nope. Di ko pa nai-try. Di pa ako nakakabili ng hardwares and peripherals nyan. Not in my needs, for now.
You can share it naman bro, ano brand nabili sa ginamit mo and how much inabot. And how and what did you do.
Typically, pwede bluetooth or by data cable ang pag-detect transfer sa smart phone or android phone, depende sa OBD2 features.
Regarding sa temp, ang boiling point ng water is 100•c. Ang close circuit or pag activate ng thermo switch to turn on the radiator fans, kadalasan naka indicate sa switch ay nasa 80•c. Reaching that temp and above it, for the coolant, activates the fans to assist in cooling down the coolant from our radiators. Decreasing the temp of our coolant to somewhere from 75~70 •c, the thermo switch deactivates our cooling fans from running. For me, I can only assume, the normal or good operating temperature for our petrol powered engines is somewhere between 40•c ~ 60•c. To have a good combustion of the air/fuel mixture entering the piston chambers.
Ano ba temp na-sense when your engine is running on idle for about 30 to 45 minute, until your rad and aux fans activates to run? Ano rin ba ang temp readings, when your radiator and aux fans, deactivates from running?
Sent from my Alcatel Onetouch Pop 3 (5) using Tapatalk
May 29th, 2017 04:27 PM #57
VinFast VF 3
