Results 41 to 50 of 57
- Jul 2012
- 345
July 25th, 2015 08:46 AM #41than ks po sa inputs. actually yung click naririnig ko po.. will try to check the functionality ng switch. mgkaiba po ang thermostat sa thermostat switch di po ba?
- Mar 2014
- 901
July 26th, 2015 12:44 AM #42
- Jul 2012
- 345
- Jul 2012
- 345
July 27th, 2015 02:43 PM #44
- Mar 2014
- 901
July 27th, 2015 11:37 PM #45
- Jul 2012
- 345
- Mar 2014
- 901
July 28th, 2015 08:04 AM #47Ok. The price may seem to be high if you compare it to what you see.😊 But that is how it is.
Hope you may find first what is needed to be replaced instead of buying it both.
Sent from my UP+ using Tapatalk
- Jul 2012
- 345
July 28th, 2015 02:48 PM #48i will. thanks sir. BTW, yung jazz ko kasi walang temp gauge.. iilaw lang yung "HOT" indicator kapag it reach a certain temp.. not sure kung nag ooverheat na ba or warning lang. anyway, pwede na ba yung nabibiling OBD2 adapter na tie up with an android app sa phone to monitor the temp? mas cheap kasi yun instead of connecting an external temp gauge. what you think? meron na po ba gumawa nito? need to monitor my car's temp moving forward to avoid serious overheating issues lalo na sa long drives.
- Mar 2014
- 901
July 28th, 2015 05:45 PM #49An OBD2 adapter that will tie up with an android up to monitor its temp. Sounds interesting to do. I don't know if someone already have done that. Try it. And if you are successful with it, share it with us bro.[emoji4]
- Jul 2012
- 345
July 30th, 2015 11:04 AM #50sir ang na measure daw ng OBD2 adapter ties up with a mobile device and using an android app like torque is yung coolant temp.. is this the same temp na ni measure ng mga nsa dashboard ng mga sasakyan?
high idle RPM at engine start
