Page 4 of 4 FirstFirst 1234
Results 61 to 74 of 74
    Aug 2004
    #61
    +1 to ^
    May coolant na pre-mixed and ready to use no need to halo (Prestone ata meron sa Ace, some casas also sell them). May coolant din na concentrate that you have to mix with DISTILLED water before using (Prestone again, some gas stations sell their own brands). Know which one you're using.
    Aug 2005
    #62
    +1 to ^
    Be careful with "generic" coolants. Some of those are so diluted you're better off with piss.
    Feb 2009
    Aug 2005
    #64
    Note: 50-50 is for more frigid climes. Go above 70% and that freezing point goes higher (meaning becomes less resistant to freezing) High coolant concentrations are not particularly relevant to our enviroment.
    Sep 2009
    #65
    Actually sinusunod ko lang ung recommendation/instruction na nakasulat sa coolant na binibili ko directly from Honda. As far as I can remember, nakalagay dun na "do not add/mix water". Since the product is from the car manufacturer, I assumed na they know what is best for my ride. FYI, never pa ako naka experience ng overheat sa car ko. With regards to the corrosion, normal na lang cguro na mangyari nga un since 10 years old na ung car. Pero hanggat wala pa naman nagiging problema radiator ko, i will still continue using 100% coolant. IMHO lang naman.
    BTW, may mga nakita na rin ako coolant sa ACE Hardware na nirerequire sya as 50% coolant and 50% water. I'm not sure if Preston ba un. Better read carefully the labels para sure.
    Aug 2005
    #66
    Quote Originally Posted by wezz_zzew View Post
    The OEM coolant from the dealership is a pre-mixed coolant. Adding water would simply dilute it.
    Actually Honda's standard long life coolants are remarkably good. 10 years or 100,000 km normally in between changes.
    But they have 2 types, if I remember correctly, one is the long life. The other I find more casual.
    Feb 2009
    Aug 2005
    #68
    Boiling point of pure glycol is 197C.
    30% or 40% mixture with water is 107C. Hence why 30% is fine.
    Your typical engine maintains anything from 82-90C. Going pure coolant does not do you any good.
    Because if you think that a higher boiling point would mean better heat transfer, you are mistaken. Pure Glycol is less than 50% as conductive as water and is far more viscous thereby also limited by its high surface tension to spread out evenly and transfer heat more effectively.
    Jul 2010
    #69
    Anti corrosion & anti rust & lubricant properties lang naman habol ko sa coolant..
    Aug 2010
    #70
    Quote Originally Posted by TheGreenThing View Post
    Correct, because plain distilled water will do. Walang epekto yung anti-freeze properties kasi nga tropical country tayo.
    Aug 2005
    #71
    Distilled water will dissolve any residue in the engine, it will hence lose its purity as soon as it is poured into your cooling system.
    Then it simply becomes as ordinary as water and will assume its corrosive properties.
    Plain distilled water alone will not do.
    Jul 2010
    #72
    Ito ang proof. Nawasak Thermostat ko dahil ordinary tap water lang gamit ko. Akala makatipid.
    #73
    Okay ba yung Top 1 coolant brand?
    mas mura kasi ito kaysa Preston..
    #74
    Quote Originally Posted by Chinoi View Post
    hindi makita yung picture sir
    someone told me na ok daw yung Shell brand na coolant.
Do you use radiator coolant?
