Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 74
    May 2005
    #21
    Ako rin gamit ng coolant/anti-freeze. Prestone. I use 50/50.
    #22
    pure distilled water (Absolute) + 500 ml. Whiz anti-rust.
    Jul 2003
    #23
    me also using 100% distilled water! but the effect is always Top Up every 2 weeks, daily use. so I want to add 1 lit. of Coolant.
    i use the pre-mixed coolant solution bought from the casa para wala ng hassle pag mi mix-mix pa ako
    #25
    Malaki ang margin of error ng coolant mix. Anything from 40% to 60% will work. Manufacturers just peg it at 50% for convenience. It will not be 'walang silbi' if you don't mix at exactly 50%. It will not eat through a gasket or destroy a radiator unless you intentionally use a 100% coolant concentrate without any dilution.
    I used a mix of distilled drinking water and coolant.
    Pero for top ups, I just use tap water. Bihira lang naman mangailangan ng top up ang Pajero. (once in 3 months? wala pang isang tabo).
    May 2004
    #26
    I agree with sir Roydok kaya ako distilled water and coolant (with anti-rust protection)
    #27
    water boils at 100 deg c at atmospheric pressure kaya un coolant sytem natin dapat pressurized to raise the boling point of water kaya nga pag me leak rad cap or other part ng system ng ooverheat at nageescape ang water vapor. un coolant nagraraise naman ng boiling point ng mixture
    #28
    no. absolute distilled water lang. top up once a month lang w/ distilled water din.
    #29
    I use 50/50 mix also, ask ko lang po sometimes yung coolant reservoir ko eh before na i use it nasa max level lang sya when i park and pop the hood i was surprised to see some coolant overflowing and spilling from the reservoir and prang na puno siya? is there something wrong? or is it normal? TIA!
    Jul 2006
    #30
    Quote Originally Posted by t2erns View Post
    In addition, ethylene glycol raises the boiling point of the cooling system, enabling one's engine to run cooler than it would had it been using plain water.
    Some say that the green coolant is not sufficient to provide adequate corrosion inhibitors, kaya some use factory recommended antifreeze which has it, and a few other additives that may be optimal for your specific car.
    For example, for the w123 chassis MB diesels w/ the iron block engines. Silicates have a polishing effect on cast iron, but is abrasive to other metals, and can erode your waterpump seals.
    http://www.benzworld.org/forums/w123...ight=phosphate
    I am led to believe that the Prestone stuff does not have any of these so that anybody can buy them at the automotive supply stores and use it in their car with minimal benefits, if at all. If you want really good protection for your car, get your OE coolant or its equivalent; it has been said that some manufacturers share the same coolant and hence, one manufacturer produces the coolant and they all are used in different car makes such as Toyota and Honda, if memory serves.
    #31
    if i am to infer from the post of those who say that they only use water (i.e. distilled or not) to top off every two weeks or once a month, it seems that the water in the cooling system reaches a point where it regularly & easily evaporates through the reservoir, thus the frequent top-off..
    this imo, should not be the case, because the cooling system is supposed to be able to retain the same amount of fluid within months without topping it off, unless there is a leak somewhere..
    i believe that the cooling system was designed in such a way that a certain mix of coolant & water is required to prevent it from evaporating faster than it should (i.e. thus eliminating the need for frequent top-offs) because of the raised boiling temperature of the mixture compared to that of water alone. thereby minimizing cooling system maintenance and improving engine heat dissipation..
    iirc, ang experience ko kasi with the cars i've maintained for more than two decades now ay never pa ako nagdagdag ng coolant/water mixture sa reservoir more than once every quarter, sometimes even longer. unless, as i've said above, there was a leak somewhere in the cooling system..
    just my :twocents: po
    #32
    I maintain a 50%-50% mix,- our vehicles retain the water-coolant, so I just check every now and then. New cars,- already had the mix,- also just check every now and then....
    :starwars:
    #33
    for those Chevy Venture owners who are having overheating problems or engine problems. it could be attributed to your DEX-Cool coolant.
    read this...
    Dex-Cool continues to cause problems
    Saturday, November 04, 2006
    Q: My 2000 Dodge 3500 van with 38,000 miles on it has been virtually trouble free until two weeks ago. The heater stopped working, so I took it to the dealer who has performed all of its services since about 18,000 miles. The thermostat was stuck open, and the cooling system was full of "gunk." They put in a new thermostat and water pump, but also recommended replacing the heater core and radiator. I asked for and received a sample of the gunk. Is there a place where I can get it analyzed? Can something break down over time and contaminate the coolant? They flushed it at 23,000 miles. -- Jill Miller, West Linn
    A: There are many analytical laboratories capable of performing the service, but save your money. Despite the previous care given to your van's cooling system, what's broken down over time -- and contaminated the coolant -- is the coolant itself.
    General Motors and Texaco introduced the first "extended life coolant," Dex-Cool, 10 years ago. With a recommended service interval of 100,000 miles or five years, it was heralded as a step forward in reducing both maintenance costs and hazardous waste streams. Other manufacturers quickly followed suit.
    Experience has shown that Dex-Cool can cause many more problems that it solves.
    Early in 2001, this column departed from its usual question-and-answer format to warn: "Technicians all over North America report that Dex-Cool can turn into rusty jelly well before the 60,000 mile mark -- even, in some cases, in as little at 30,000 miles. The jellied coolant is extremely difficult to remove from the system. Depending upon the severity of the problem, the heater core, radiator, and core plugs may need to be removed and/or replaced. Repairs can cost hundreds dollars or more, and aren't easily performed at home."
    In the premier issue of Master Technician magazine (www.mastertechmag.com), editor Bob Freudenberger further explains that Dex-Cool is "based on Organic Acid Technology (OAT), and its additive package can keep corrosion away for a very long time indeed.
    "The trouble is, this admirable property is defeated by one simple thing: air. If the coolant level in the system should be allowed to drop so that all surfaces aren't continually immersed, oxidation occurs rapidly. The dusty deposits that form accumulate into ugly glop that clogs up the works."
    Freudenberger further explains that a primary organic acid in OAT, sodium 2-ethyl hexanoate, is known to soften certain plastics. Given the increasing use of plastics in modern engines -- including waterpump impellers in many Chrysler V-8s -- OAT is now the primary culprit in many of today's cooling system problems.
    What to do? If your vehicle is still under warranty, and factory-filled with OAT, have the cooling system checked and serviced regularly, and keep it topped up with OAT to maintain the warranty.
    In all other cases, have the OAT coolant removed, and the system thoroughly flushed. Refilling with tried-and-true green antifreeze should work just fine if you don't mind returning to a two-year cooling system service interval.
    If you want to stay modern, refill with a coolant meeting European "G-05" standards. These coolants use a Hybrid Organic Acid Technology (HOAT) that provides the longevity of OAT without its risks.
    Jun 2006
    #34
    madami talagang horror stories about dexcool.
    Jul 2006
    #35
    Quote Originally Posted by slamtaz View Post
    A very good point, I should add.
    Nov 2003
    #36
    a healthy cooling system does not need topping up.
    Nov 2006
    #37
    Mga dudes
    Question lang...
    Sa coolant..
    What if 2nd hand lang car mo tapos ung rad mo surplus... SHould u still use coolant?
    Sabi-sabi kasi nilalagay lang ang coolang if bago ung cars, if luma na it's better na daw ung distilled water..
    If maglalagay ka nman.. db kelangan i-drain mo ung rad mo...
    every when naman yun? (2weeks, 1month)????
    Thanks!
    #38
    Yes, you should. Coolant is not only for the radiator, it is also for the rest of the cooling system which involves the water pump, etc.
    I mix coolant with distilled drinking water. Check the specific coolant you will be using for the correct mix (unless it's pre-mixed).
    You need to drain the whole cooling system. That includes water within the water jackets and other areas. Your mechanic should know how to do this.
    Intervals vary with vehicle. Check your owner's manual.
    Nov 2006
    #39
    pano po mag DIY flush ng rad?
    mahirap bang i-DIY ito? or better to have a mechanic do this?
    #40
    It's not that hard. But coolant should be properly disposed of [not flushed down the drain] kaya madalas sa gas station ko na lang pinapagawa. Kasi sabi ni chieffy dati, may mga iniimplement silang policies regarding waste disposal sa mga gas stations.
    Ethelyne glycol tastes good but is very poisonous kaya tepok agad ang mga stray animals na makakainiom nito.
    Tastes like Kool Aid daw.
Do you use radiator coolant?
