Results 261 to 270 of 273
January 17th, 2019 08:14 PM #261
there are so many guides online. if not ask/call a friend before spending a dime..
January 17th, 2019 10:06 PM #262
Ganyan talaga Rapide, they go the extra mile in finding things to fix even if there's none.
If you go there for just a simple job, they will give your car a free complete check up. This is what happened to me, they said I needed to replace my suspension and nainis pa ako sa Nissan for not detecting that problem since regular PMS ako sa kanila dati until I tried Rapide. Dahil wala naman akong nararamdaman, sige tuloy lang ride, 250k kilometers later, ayos pa naman siya.
Talo pa nila ang BDO, they really find ways
- Jan 2019
- 7
January 17th, 2019 11:29 PM #263
- Feb 2019
- 2
February 1st, 2019 10:28 AM #264bakit kaya yung ac ng sasakyan ko saka lang gumagana pag umakyat na sa 1/4 yung temp gauge which takes around 10 - 15 minutes? As in saka lang nag-eengage yung compressor..... Sign kaya ito ng low refrigerant o failing compressor? Pag gumana naman, malamig pa talaga ang buga. Ano sa tingin niyo mga sir? Sasakyan ko nga pala ay sportivo.
- 52,731
February 1st, 2019 10:44 AM #265
February 1st, 2019 10:53 AM #266
- 52,731
February 1st, 2019 10:58 AM #267yes, there's a lot of garbage in the innernet.
intentional or otherwise.
we have to be discernible.
as kiss above says, "air your concerns here".
- Nov 2012
- 84
March 21st, 2019 11:47 PM #268Medyo naranasan ko ngayon yung AC problem to my 6 year old car.
Had my compressor replaced last january. Bought oem compressor online for 14k. Pina install ko sa shop. After 2 weeks medyo nawala lamig, so dagdag freon. Tapos 2 weeks ulit nawala na naman so dagdag ulit freon. Yun pala may maluwag na nut sa compressor kaya may tagas na langis. Tapos biglang nag release ng freon kasi nag high pressure.
Pina check ko sa isang ac shop ang sabi baka daw hindi masyado nalinis yung ac system kaya they suggested na linisin ulit at palitan agad yung compressor kahit kakabili ko lang. Baka daw may damage na yung compressor kasi nag release na ng langis. 28k yung charge nila for the cleaning and brand new compressor!
Naghanap ako ibang shop sabi naman ok pa yung takbo ng compressor. Nilinis lang ulit yung condenser at evaporator. So far ok naman. Sana hindi na ulit magka problem.
Sent from my LDN-LX2 using Tapatalk
January 9th, 2020 10:27 PM #269
Do you have a suggestion on my car aircon problem?
Yung sa may passenger side malamig yung nilalabas pero sa driver side eh hangin lang walang lamig.
Sent from my Redmi Note 5 using Tapatalk
- 52,731
January 10th, 2020 10:06 AM #270
high idle RPM at engine start
