Page 14 of 14 FirstFirst ... 41011121314
Results 261 to 273 of 273
    there are so many guides online. if not ask/call a friend before spending a dime..
    Jan 2016
    #262
    Quote Originally Posted by pacoloco View Post
    Ganyan talaga Rapide, they go the extra mile in finding things to fix even if there's none.
    If you go there for just a simple job, they will give your car a free complete check up. This is what happened to me, they said I needed to replace my suspension and nainis pa ako sa Nissan for not detecting that problem since regular PMS ako sa kanila dati until I tried Rapide. Dahil wala naman akong nararamdaman, sige tuloy lang ride, 250k kilometers later, ayos pa naman siya.
    Talo pa nila ang BDO, they really find ways
    Jan 2019
    #263
    Yup but only problem is if you dont have many friends that know car maintenance... but hey thats why we have these forums right? A lot of great info here, just a bit hard trying to dig it all up.
    Feb 2019
    #264
    bakit kaya yung ac ng sasakyan ko saka lang gumagana pag umakyat na sa 1/4 yung temp gauge which takes around 10 - 15 minutes? As in saka lang nag-eengage yung compressor..... Sign kaya ito ng low refrigerant o failing compressor? Pag gumana naman, malamig pa talaga ang buga. Ano sa tingin niyo mga sir? Sasakyan ko nga pala ay sportivo.
    #265
    Quote Originally Posted by YAMERO!!! View Post
    pa-tingin nyo po sa aircon shop.
    baka kung saan kinabit ng dating nangumpuni, ang aircon thermostat.
    puede rin naman, na nag-kataon lang.
    baka nga kulang freon. baka rin madumi lang ang evaporator and condenser.
    Dec 2009
    #266
    Yah there are many infos here (pati aircon ng bahay)
    If you are having difficulty digressing all the thoughts suggested here just go get an assessment at the shop (dont let them fix it just yet)..Then ask for opinions here
    #267
    yes, there's a lot of garbage in the innernet.
    intentional or otherwise.
    we have to be discernible.
    as kiss above says, "air your concerns here".
    Nov 2012
    #268
    Medyo naranasan ko ngayon yung AC problem to my 6 year old car.
    Had my compressor replaced last january. Bought oem compressor online for 14k. Pina install ko sa shop. After 2 weeks medyo nawala lamig, so dagdag freon. Tapos 2 weeks ulit nawala na naman so dagdag ulit freon. Yun pala may maluwag na nut sa compressor kaya may tagas na langis. Tapos biglang nag release ng freon kasi nag high pressure.
    Pina check ko sa isang ac shop ang sabi baka daw hindi masyado nalinis yung ac system kaya they suggested na linisin ulit at palitan agad yung compressor kahit kakabili ko lang. Baka daw may damage na yung compressor kasi nag release na ng langis. 28k yung charge nila for the cleaning and brand new compressor!
    Naghanap ako ibang shop sabi naman ok pa yung takbo ng compressor. Nilinis lang ulit yung condenser at evaporator. So far ok naman. Sana hindi na ulit magka problem.
    Sent from my LDN-LX2 using Tapatalk
    #269
    Do you have a suggestion on my car aircon problem?
    Yung sa may passenger side malamig yung nilalabas pero sa driver side eh hangin lang walang lamig.
    Sent from my Redmi Note 5 using Tapatalk
    #270
    Quote Originally Posted by james00112233 View Post
    what car model are we refering to, po?
    #271
    Crv 3rd gen
    #272
    Nangyari sa car ko ito (not CRV) ... low on freon, tiny leak on evaporator.
    hth
    Blend door actuator most likely or a leak.
    Leak test is easy. Meron naman pressure tester ang mga ac technicians.
    Blend door actuator...maybe the tech can test with a scanner if it is opening and closing? Not sure..
Car Aircon Problem
