Results 201 to 210 of 273
- Dec 2005
- 8
September 8th, 2016 12:15 PM #201
- 52,701
- Dec 2005
- 8
September 8th, 2016 12:37 PM #203
- Dec 2005
- 8
September 9th, 2016 01:16 PM #205yung huling ac tech na tumingin e ang sabi po e dalhin na lang sa casa at di nya makuha kung ano sira. Me nagsabi rin po sa kin na pwedeng pressure switch, kaso pano po ba malalaman kung sira na yun?
- 52,701
September 9th, 2016 01:50 PM #206
- Dec 2005
- 8
September 9th, 2016 02:08 PM #207
- Apr 2012
- 2
September 10th, 2016 05:25 PM #208Hello sirs, meron po ba kayo idea magkano ang range ng replacement ng clutch assembly for Honda Jazz 2009? Sobrang mahal kasi sa Honda e, and saan ang recommended, called Coolmate earlier 9500 ang quote sakin parts and labor, reasonable ba? Thank you!
- Mar 2014
- 901
September 10th, 2016 07:08 PM #209
- Jul 2016
- 939
September 10th, 2016 07:40 PM #210Problem nowadays is high tech na mga oto. Incorporated na sa ECU ang A/C system. So yes, tama tech nya when it says dalhin sa casa since dun mababasa ang fault code or performance ng mga acu sensors.
Di na uso pressure switch na ijujump mo lang at aandar na compressor pag sira. Karamihan pressure sensor na gamit. Alam na ng ECU kung ilan ang actual pressure sa high side to smoothen out idle stability with A/C on and different ambient temps.
Pede rin na ung climate control.
Pede rin ung temp sensor sa evaporator.
Happened to me before, okay lahat ng ac hardware pero ayaw i command ni ACU mag ON. Suko lahat sa banawe. No CEL pero itried using my elcheapo obd2 scanner na rin pero alang mabasa na code.
Went to casa to diagnose and dun nakita ung code na p0532(ref low input.)
So balik ako banawe to change the refrigerant pressure sensor pero ganun pa rin ala pa rin ayaw pa rin mag ON. I then checked my wiring from ECU to ref sensor at dun ko nakita may putol kagat ng daga.. ;p
