Results 1 to 20 of 273
    Quote Originally Posted by Janemar View Post
    Nope sir, nasa ilalim ng dash board. I dont have a wiring diagram for my car so i have to trace all 200+pinouts ng ECU connector to look for the ACU pressure signal wire. Nung walang tumunog sa tester, dun ko nalaman may break sa wire somewhere at saka nag hanap hanap.. hehe..
    3 wire sya sensor ang acu press. +5vdc reference, ground and signal fire going to ecu.
    The +5v dc ref voltage is also same with the other sensors like the TPS and MAP. Good job on tracing your wires with a use of a multimeter tester.
    Sent from my UP+ using Tapatalk
    Apr 2012
    Hi mga boss! natabunan kasi yung question ko earlier. Ask ko lang po magkano nag range ang replacement ng clutch assembly? Yun kasi findings ng honda eh sobrang mahal kapag sa kanila. For Honda Jazz 2009 po mga sir! Thank you!
Car Aircon Problem
