Page 20 of 28 FirstFirst ... 10161718192021222324 ... LastLast
Results 191 to 200 of 273
    #191
    Hi. Tanong ko lang po kung ano posibleng sira ng aircon ng altis 2005 E model (climate control) ko, nawala po lamig nya kahapon after ko gamitin, samantalng mula banawe hanggang pasig ay di po nawalan ng lamig? Bagong palit po magnetic clutch at buo po mga fuse at relay, at mas lalo na pong kumpleto ang freon. Help naman po dahil me mga nagsasabi palit compressor pero nag aalangan po ako. Thanks po sa input.
    #192
    Quote Originally Posted by starscream_7phi View Post
    biglang nawala ang lamig?
    maybe your freon leaked away? if you know how to interpret sight glass patterns, you can determine if you still have freon.
    or maybe, the magnetic clutch is defective?
    bring it to the aircon shop where you just came from. they usually warranty their works.
    don't palit your compressor until you find out what the problem really is. for all we know, your compressor is perfectly fine.
    Sep 2014
    #193
    pano ba malalaman pag kulang sa freon dIY? ngaun, kahit ano aircon shop lagi sinasabi kulang tapos cleaning.
    #194
    walang kabula-bula po. parang walang laman.
    my aircon shop suki says something else.
    Sep 2014
    #195
    pano kung walang sight glass?
    you mean pag hindi bumubula, walang laman? i thought pag bumubula may hangin or may mali sa compresion sa system
    #196
    kung walang sight glass, you have to bring it to the shop and let them use their gadgets to measure the pressures.
    pag bumubula, may laman, kahit kaunti. pag hindi gumagana ang magnetic clutch, walang bula. pag full, baka may makikita ka ng kaunting galaw.
    there is an overlapping spectrum from full to partially full to absolutely empty. hence the dials and tubings they attach to the filler/inspection nozzles.
    #197
    What's the last thing na pinagawa mo sa A/C mo? Lahat ng sinabi mo possible reason bakit nawala lamig.
    If mag palit ka ng magnetic clutch then start from there
    Check Mo kina Hinde na ba dumidikit magnetic clutch pag on mo?
    #198
    ako, yung magnetic clutch.
    tuwa nga ako at yun lang. mura, kumpara sa ibang piyesa.
    #199
    Baka nga pwede bawasan lang ng washer mas tipid.
    #200
    dikupa nasubukan yan.
    baka naman, dumalas ma-diskaril ang belt?
Car Aircon Problem
