Results 231 to 240 of 273
May 12th, 2018 08:02 PM #232
May 12th, 2018 10:02 PM #233
Hi,
Can you explain the difference between the two, thermostatic expansion valve and cycling orifice tube type?
From what I know, a thermostatic expansion valve works by sensing the temperature after the solenoid valve going to the evaporator. From there, the liquid inside the bulb will expand and push through the needle like opening of the thermostatic expansion valve thereby throttling the refrigerant.
I might have mixed everything or something is not in the proper order or everything is incorrect.
I hope I'm not asking too much.
EDIT: I found this article. However, I don't simply trust online contents so I'm relying more to textbooks. Unfortunately, I don't have my textbook right now. The consequences of always missing my classes...
Cycling Clutch Orifice Tube vs Thermostatic Expansion Valve
- Mar 2018
- 50
June 11th, 2018 03:40 PM #234mga sir may alam na ba kayo na expert mechanic na nagbabawas ng spacer dun sa magnetic coil?
yun kasi ang tingin kung sira sa akin di na nag eengaged pag mainit na. so pag natrapik ako mga 1hour wala na aircon. pag nakapag pahinga balik ulit hehe. may nabasa kasi ako nun kaso sa lucena pa. try ko muna sana bago palitan ng magnetic coil. thanks in advance
June 13th, 2018 02:05 PM #235
- Sep 2007
- 266
June 13th, 2018 02:51 PM #236Mukhang spacer issue lang nga yan. Sa totoo lang most aircon repair shops can do that but gusto kasi ng management na sabihin ng technician sa customer palitan na magnetic clutch assembly or yung buong compressor. Pa sideline ka na lang sa aircon technician at usually P500 lang yan. Tatanggalin engine under cowl cover and maybe even the wheel well cover depende sa pwesto ng aircon. After that baklas yung pressure plate tapos sisikwatin na yung spacer (assuming may spacer ka pa ha). Usually nililinis rin yung clutch surfaces with very fine liha para tanggal dumi at magkaroon ng kapit and then balik lang lahat in reverse order. Wala pa isang oras tapos na yan.
Yung sa akin dati after nabawasan ng isang spacer gumana pa ng maayos for three years.
- Jun 2018
- 2
June 13th, 2018 06:40 PM #237Good day po,
Newbie. May tanong lang po sana ako regarding sa compressor ng car ko. BTW , its 2015 Hyundai Accent (Gas). Bigla lang nawala ang lamig ng aircon.
Pina check ko, Compressor daw bumigay na. Dapat daw palitan. Eh mag 4 years pa po ang kotse ko. Posible po ba masira agad ang compressor pag hindi naalagaan?
Additional info, had an accident last year, may bumanggang motor sa harap ko tapos first time ko nagpa aircon servicing 6 months ago.
Thank you po sa sasagot.
June 13th, 2018 06:53 PM #238
- Jun 2018
- 2
June 13th, 2018 07:22 PM #239
June 13th, 2018 07:37 PM #240
You said you don't drive to work daily. Even if you do, your Altis is a great commuter car. With...
Toyota 3ZR-FE
