Results 111 to 120 of 273
- Mar 2014
- 901
June 16th, 2016 12:23 AM #111Palitin na po ba ang A/C Compressor kapag minsan nagana umikot at minsan hindi naikot( as in stuck up at di mapaikot ng belt yun compressor at yung belt lang ang naikot)?
Starmobile Up+
- 52,731
June 16th, 2016 12:32 AM #112perhaps it is not the compressor.. perhaps it is just the clutch. clutches are cheap.
also, it could be compressor bearing.
some years back, my compressor seized. the repairman said it's the bearings, and bearings can't be replaced.
years later, i met this guy from the casa. he said that they actually had bearing repair kits in stock, but few asked for them. it would appear, "they made more money replacing compressors rather than repairing their bearings".
go figure...Last edited by dr. d; June 16th, 2016 at 12:56 AM.
- Mar 2014
- 901
- Jun 2008
- 1,741
June 21st, 2016 11:30 AM #114Armature of what?? AC compressor is belt driven.
Sent from my Lenovo A7000-a using Tsikot Forums mobile app
- Mar 2014
- 901
June 21st, 2016 02:38 PM #115The armature bolt inside, where the armature plate is fasten by nut.
Starmobile Up+
- Jun 2008
- 1,741
June 21st, 2016 04:02 PM #116Ouch! Clutch plate ang alam ko na pangalan nyan. First time ko makita ang drawing na armature plate ang label. Ang nasa isip ko "armature ng electric motor"
- Mar 2014
- 901
June 21st, 2016 08:27 PM #117Isang component na nga lang natitira na dapat palitan, yung ang condenser. Pero kapag naging hilaw pa rin ang lamig. Diko lang sure kung ang solution, ay maglagay dagdag ng "compressor oil" sa a/c compressor. Or check and correct the pressure both in low and high fitting lines, of charged freon in the system.
Starmobile Up+
- Mar 2014
- 901
June 21st, 2016 10:45 PM #118I just had my brand new a/c compressor installed. Also replaced and installed a new air drier. And had the evaporator cleaned awhile this morning, in an Aircon Shop here in our area. Na-obserbahan ko lang, after ma-vacuum at ma-refill ng freon habang nasa shop. Habang umaandar, nag auto on and off ang a/c, with setting of thermo at 60% and blower fan at #2. Pero when i got home, nakagarahe sa may habong o lilim and setting the thermo at somehere 70% to 100% and placing the fan at #3 and #4. Ang tagal mag cut off ng a/c. Parang di pa ma-reach ng a/c yung thermo setting at ang tagal para mag auto off. Lack of charge freon kaya ang problema?
Starmobile Up+
- Jun 2008
- 1,741
June 22nd, 2016 03:24 PM #119Sadyang matagal mag cut off pag mataas ang fan speed. Volume lang ng air ang nag increase pero lamig ng hangin hindi.
- Mar 2014
- 901
June 22nd, 2016 05:18 PM #120Before I had problem with the a/c compressor. My car a/c system automatically on and off whether the fan blower setting is at #4 or #3 and thermostat setting whether from 70% to 100% at engine idle speed. And from those settings, when driving and accelerates the engine, it auto cuts off the a/c compressor. That is why I am wondering if they charge enough freon or not.
Starmobile Up+
Xiaomi E-Car
