Results 101 to 110 of 273
February 10th, 2016 04:13 PM #101
Yung highside dapat Ang reading between 150psi-250psi-- pag mataas pa Dyan hilaw na Aircon mo
- Jun 2008
- 1,741
February 10th, 2016 07:15 PM #102Ask ko lang po. Na vacuum ba ang system noon ginawa ito (palit evaporator, filter, etc.)?
- Feb 2016
- 19
February 15th, 2016 11:03 AM #103thanks mga papsie.. problem solve.. replaced compressor, 70/290-300(low-high reading) ata..wala na talaga bumigay na.. stock compressor pa yun considering its 98 model 17 years old hahaha, palit compressor nissan parin, super lamig nanaman
- Jun 2008
- 1,741
February 15th, 2016 12:55 PM #104Bakit kaya di na detect ang compressor problem noon ng first time ka nag pagawa??
February 15th, 2016 02:29 PM #105
^ hindi kasi basta basta nasisira compressor ng ac kaya ito lagi ang last sa checklist.
Unless may nakita sila sa physical characteristics na my tama na like oil leak or nag iingay na.
Pwede rin naman kasi i overhaul yan palit ng parts sa loob
Sent via Tapatalk
- Jun 2008
- 1,741
March 18th, 2016 11:29 AM #106One simple test to do to check if compressor still good. Pasip-sipin ang compressor sa atmosphere. with discharge side disconnected, takpan ng thumb ang outlet. Kung ayos pa ang compressor mag build up yan ng pressure hanggang di mo na kaya pigilan. You can also do it using pressure gauge.
- Jul 2015
- 14
April 11th, 2016 01:02 PM #107Good day po!
Pag nagpapakarga ako ng refrigerant, lumalamig sya pero yung lamig tumatagal lang ng ilang buwan (kalahating taon maximum). Pinacheck ko evaporator and nakitang may leak nga sya. Pinapalitan ko na yung evaporator. Napansin ko yung isang gumagawa na parang may tube na nilagay sa may compressor. Hindi binaba yung compressor. Parang may butas lang sa side tapos dun nakasaksak yung tube na may embudo sa dulo. Tinanong ko kung ano yun, sabi niya langis daw. Kasi daw pag tulad nun na may papalitan na part (in this case yung evaporator), dapat daw lagyan ng langis yung compressor (Tama po ba?)
The next day, normal naman yung a/c, malamig dahil bagong karga ng freon. Pero habang nag ddrive, meron biglang tutunog. Yung sound niya parang katunog ng fanbelt o parang pressurized air na lumalabas. Bigla na lang sya tutunog at naririnig ko sya mula sa loob ng sasakyan. Minsan pag nakatigil sa traffic, minsan nasa expressway, biglang tutunog. Yung sound niya lasts for minimun 4 secs to maximum mga 15 secs.
Nitong week na to inobserbahan ko yung sasakyan ko. Napansin ko pag matagal nang naka park yung sasakyan, then gagamitin ko, pag kambyo ko sa primera at pag gumalaw na ako ng konti, tumutunog sya. Ilang beses na nangyari na ganun. Kahit pagkastart ko and mag idle (neutral) ako ng 5 mins, once kinambyo ko to 1st gear and gumalaw na ng bahagya, tutunog nanaman. Sinubukan ko minsan nung na-timingan kong tumunog, pinatay ko yung aircon. Bigla rin naputol yung tunog. So na-conclude ko na BAKA sa compressor galing yung tunog.
Nabasa ko dito sa forums na ang dahilan ay maluwag na aircon belt o bearing sa loob ng compressor. Baka nung nilalagyan ng langis, niluwagan yung belt? Pwede po kaya yun?
Hingi po sana ako ng advice/opinion niyo.
- Jul 2015
- 14
- 52,731
- Apr 2012
- 3
May 13th, 2016 01:52 PM #110pa help naman po, Isuzu trooper bighorn model 99 ung akin, 4jg2.
napalitan ko na po ung
receiver drier
Zexel compressor
expansion valve
front evaporator
cleaned AC system
pero hilaw pa din po lamig nung auto ko. kahit linisin ung condenser.
kelangan ko po bang palitan na din pati condenser? thnks
Automatic po Sir
