Results 1 to 10 of 12
- Dec 2008
- 33
February 19th, 2010 09:11 PM #1my car is a 2000 honda civic. pinalitan ko yung high pressure hose ng ac kasi may leak after oneweek dinala ko sa aircon shop para malagyan ng freon after 4 days wala na po yung lamig pero may freon pa sya... ano po kaya ang problema ng ac ko? pls help me bago po ako pumunta sa shop ulit.
February 19th, 2010 09:53 PM #2
Obviously you don't have freon in your a/c anymore.
Check for leaks before having more freon pumped into your A/C.
February 19th, 2010 10:49 PM #3
- Dec 2008
- 33
- Jul 2007
- 195
February 20th, 2010 12:03 AM #6If walang freon leak, first check the belt, it could be slipping. If it's not slipping, check the compressor's magnetic clutch, it might not be engaging, that is, hindi pumipitik ang compressor. Kung hindi pumipitik ang compressor, it could be a problem with the thermostat. If it's the thermostat and masyadong mahal ang orig, pwede kang magpa-modify nalang using a generic thermostat, alam na yun gawin ng aircon tech and the part won't cost more than 500. HTH
- Mar 2009
- 51
- Apr 2008
- 537
February 20th, 2010 12:48 AM #8tingin ko bukod sa iba pang problema na nabanggit dito ng mga nag reply baka may problema din ang expansion valve mo
- Oct 2009
- 72
February 20th, 2010 07:53 AM #9As you said, meron pang freon, my question is how did you arrived that there is still (freon) refrigerant in you A/C, did you just remove the charging cap and press the valve and notice there is still some pressure in it, mere doing this is not a guarantee that you still have enough refrigerant in your a/c that could cool you car. To know the exact working pressure, use a test manifold gauge.
THE AUTO SPECIALIST
- Mar 2006
- 607
February 20th, 2010 08:26 AM #10kailangan muna irecover yung refrigerant to find out if there is enough freon in the system. and go from there.
possibilities are the system is undercharged ,ovecharged, leak within the system, electrical trouble .
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
