Results 1 to 12 of 12
    Dec 2008
    my car is a 2000 honda civic. pinalitan ko yung high pressure hose ng ac kasi may leak after oneweek dinala ko sa aircon shop para malagyan ng freon after 4 days wala na po yung lamig pero may freon pa sya... ano po kaya ang problema ng ac ko? pls help me bago po ako pumunta sa shop ulit.
    Obviously you don't have freon in your a/c anymore.
    Check for leaks before having more freon pumped into your A/C.
    Jan 2010
    Quote Originally Posted by icedrop View Post
    check mo din kung umaandar yung compressor. baka kasi fan lang ang umaandar pero yung compressor hindi. nangyari sa akin yun dun sa adventure namin. not really sure kung ano yung problem nya pero tinanggal-kabit ko lang yung fuse ok na sya.
    Dec 2008
    sir, may freon naman yung ac ok din po yung compressor...
    Nov 2007
    cleaning is necessary
    - condenser
    -coil
    - hose
    If walang freon leak, first check the belt, it could be slipping. If it's not slipping, check the compressor's magnetic clutch, it might not be engaging, that is, hindi pumipitik ang compressor. Kung hindi pumipitik ang compressor, it could be a problem with the thermostat. If it's the thermostat and masyadong mahal ang orig, pwede kang magpa-modify nalang using a generic thermostat, alam na yun gawin ng aircon tech and the part won't cost more than 500. HTH
    maybe the filter dryer is already clogged. .
    Apr 2008
    tingin ko bukod sa iba pang problema na nabanggit dito ng mga nag reply baka may problema din ang expansion valve mo
    Oct 2009
    As you said, meron pang freon, my question is how did you arrived that there is still (freon) refrigerant in you A/C, did you just remove the charging cap and press the valve and notice there is still some pressure in it, mere doing this is not a guarantee that you still have enough refrigerant in your a/c that could cool you car. To know the exact working pressure, use a test manifold gauge.
    kailangan muna irecover yung refrigerant to find out if there is enough freon in the system. and go from there.
    possibilities are the system is undercharged ,ovecharged, leak within the system, electrical trouble .
    Dec 2008
    thank you po sa mga suggestions nyo...marami po akong nakuhang ideas. God bless you all!
    Dec 2008
    mga bosing...ok na po yung aircon ng honda civic ko, cleaning lang at may nakita na konting leak sa high preasure hose kaya pinalitan. they charge me for only 1,950 only... less 150 petot for tsikot member. kya bale 1,800 na lang. super lamig na naman si vtec hehe! thanks boss joel and his wife and also ramil yung technician nila. ok tlagang mag pagawa sa ceejay's las pinas. free coffee and softdrinks pa!
a/c nawala ang lamig...pls help me!
