Results 11 to 16 of 16
- Jun 2010
- 1
June 11th, 2010 11:57 AM #11gud day mga sir, may problem ako about my tamaraw fx 95 model diesel, kc yung aircon ko pag naka stop lalo pag traffic umiinit yung labas ng aircon tapos tumataas ang temperature, kaya ginagawa ko pag traffic na pinapatay ko na yung aircon kc baka mag overheat makina ko. sa tingin nyo po ano sira ng aircon ko?sana matulungan nyo po ako kc malaki narin nagagastos ko sa aircon ko,, sinubukan na rin namin pinagawa 2x na pero ganun parin ang sira. yung pinagawan namin sabi nya maayos daw yun pro mdyo mahal ang gagastusin about 6k daw pro di pa daw sya sure kung yung gagawin nya eh yun ang sira talaga. syang naman kung di sya sure kc gagastos kami. sana matulungan nyo po ako. maraming salamat po....
- 25
June 16th, 2010 01:26 PM #12sir, normal problem na po yan sa mga FX ride. some owners will attach 2 aux fan in front of the condenser to help aircon condensation process. Ang pde mo pa check sir or you can check it yourself muna.
1. Revolution of radiator fan. -- observe the fan rotation for a while, then increase the rpm/rev of your FX ride. kapag same speed/rotation pa din at idle speed and higher rpm then you need to check the silicone oil of the radiator fan
2. with a/c running and with idle engine rpm for about 5-10mins. observe the temp gauge and a/c blower temp. if not cool or parang di malamig. try to splashing some water sa condenser making it all wet. then check again the panel temp gauge and a/c blower temp. kung medyo bumaba ang temp at mdyo lumamig un hangin ng aircon. have your condenser flushed with nitrogen and not just compressed air.
If lumalamig ang aircon mo kapag highway speed or high rpm. the remedy would be, installation of 2 aux fans in front of your condenser to compensate the air flow through it.
- May 2010
- 18
June 18th, 2010 07:20 PM #13try mo rin palinis yung radiator, baka di makacirculate ng maayos yung water.coolant pag traffic with aircon on kaya tumataas temperature.
- Nov 2007
- 164
June 22nd, 2010 08:00 PM #14
- Aug 2009
- 178
May 20th, 2014 01:43 PM #15My advance apology/ies po sir testa but just browse within tsikot regarding the present diagnostics on my pajee's aircon compressor. Almost the same with what you have posted except that the reason for the non-cooling of the aircon was the broken magnetic clutch. within a period of less than 6 mos. bumigay yung naunang surplus nila thus pinalitan ulit surplus and balik lamig ulit. Was advised na may "play" na raw shafting kaya nasisira yung nakakabit dito na magnetic clutch pulley.
Question po: any idea po if ano yung tolerable clearance ng "play" na ito?
- May 2014
- 72
May 29th, 2014 11:39 PM #16
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
