Quote Originally Posted by gelver_78 View Post
gud day mga sir, may problem ako about my tamaraw fx 95 model diesel, kc yung aircon ko pag naka stop lalo pag traffic umiinit yung labas ng aircon tapos tumataas ang temperature, kaya ginagawa ko pag traffic na pinapatay ko na yung aircon kc baka mag overheat makina ko. sa tingin nyo po ano sira ng aircon ko?sana matulungan nyo po ako kc malaki narin nagagastos ko sa aircon ko,, sinubukan na rin namin pinagawa 2x na pero ganun parin ang sira. yung pinagawan namin sabi nya maayos daw yun pro mdyo mahal ang gagastusin about 6k daw pro di pa daw sya sure kung yung gagawin nya eh yun ang sira talaga. syang naman kung di sya sure kc gagastos kami. sana matulungan nyo po ako. maraming salamat po....
sir, normal problem na po yan sa mga FX ride. some owners will attach 2 aux fan in front of the condenser to help aircon condensation process. Ang pde mo pa check sir or you can check it yourself muna.
1. Revolution of radiator fan. -- observe the fan rotation for a while, then increase the rpm/rev of your FX ride. kapag same speed/rotation pa din at idle speed and higher rpm then you need to check the silicone oil of the radiator fan
2. with a/c running and with idle engine rpm for about 5-10mins. observe the temp gauge and a/c blower temp. if not cool or parang di malamig. try to splashing some water sa condenser making it all wet. then check again the panel temp gauge and a/c blower temp. kung medyo bumaba ang temp at mdyo lumamig un hangin ng aircon. have your condenser flushed with nitrogen and not just compressed air.
If lumalamig ang aircon mo kapag highway speed or high rpm. the remedy would be, installation of 2 aux fans in front of your condenser to compensate the air flow through it.
