Page 14 of 59 FirstFirst ... 410111213141516171824 ... LastLast
Results 261 to 280 of 1163
    Oct 2005
    #261
    guys, first time ko pagawa ke Mang Mario, galing ako dun kahapon(12/08)....ung kotse ko bglang uminit....i was thinking of having my car check at Honda pasig or Rapide antipolo...pero buti nabasa ko itong thread na ito...i thought compressor me problema....un pala condenser fan lang...1.5hours lang ginawa! mura p! instead of thousands of pesos sa casa...
    very reliable talaga si Mang Mario...
    nakita ko na rin ung labrador nila, kahabulan ung si giant....
    #262
    Papagawa ko sana yung Sentra 1.4JX. Palit expansion valve, magnetic coil, drier. Estimate kay Mang Mario including parts, labor, and materials ay Php 2,700.00 (hindi pa ko tumatawad niyan).
    Kaya lang from duty ako and sobrang antok. Inutos ko na lang sa driver na dalhin the next day.
    Sa ibang shop dinala (somewhere in 10th avenue ata). Total bill for the same work: Php 7,000.00!!!
    POTANG INA! Sana nakitulog na lang ako kina Mang Mar habang ginagawa!
    Jun 2004
    #263
    HAHAHAHA!
    oops, sori Ser OTEP....di ko po sinasadyang tawanan ang inyong kamalasan....
    Natawa lang talaga ako dito.....oo nga, sana ay natulog na lang kayo kay Mang Mario!
    #264
    Open din ba ang repair shop ni Mang Mario on Sundays? If yes, what time do they open on Sundays. And hindi ba sila mahirapan mag-hanap ng aircon parts on Sundays. I'll bring in our Hi-Ace pero Sunday ko lang madadala as everyday hauler kasi namin ito.
    #265
    Open if you call ahead and wala siyang ibang lakad. May stash of parts din siya sa bahay. Pero pilitin mong umaga kasi halfday lang ang ibang supplier bukas.
    Jul 2004
    #266
    ano landline or cellphone number ni Mang Mario? open kaya sila this Friday?
    Mar 2003
    #267
    hmm...parang nandun ako last dec. 23 ata yon...so i guess open den sya ng 30...=)
    kakagising lang nga ni mang mario nung pumunta ako kaya mejo masungit...pero after a while, kwentuhan na.=)
    and i'll say mura talaga! will definitely go back pag may prob ulit.
    Sep 2004
    #268
    went there last december din before christmas. nawala lamig ng aircon ko. his son removed my evaporator, filled it with air and saw that there was a leak. i was expecting to hear that my evaporator needs to be replaced. but his son said that he might be able to repair it and so he did. he welded the leaking part and tested it (no more leaks!), cleaned my evaporator, then he reinstalled it. after the work, i asked mang mario's wife how much my damage was while in the process pulling out 3 P500 bills. to my astonishment, she said that my bill was P800 only! now that is cheap! and all that work was done in 45 minutes! what can i say? i was amazed by this family. may god bless them.
    #269
    Depende sa area ng leak kung magagawa. Kung kaya, they will repair it. Na-try na din namin dati, tumatagal naman.
    Dec 2002
    #270
    malas ko yesterday may fun run ang pajero clan ng mymitsu. Nung pauwi na ako bigla nalang ayaw mag on ang compressor. Nakita ko pumutok ang fuse. Inisip ko baka kasi luma ng yun fuse kaya lagay ulit ako ng bago. Naks pumutok ulit. hay gastos uli baka shorted and clutch ng compressor sa linggo ako pupunta kay mang mario. Buti otep laki talagang tulong mo sa pag refer sa amin kay mang mario
    #271
    Sino nakapaggawa na ng compressor bearing replacement kay Mang Mario na calsonic? mga magkano inabot?
    Also, pag pinalitan bearing, tanggal din ba freon? If so, pwede na isabay R134 conversion?
    Sep 2005
    #272
    ask ko na rin sa inyo guys! ano-ano ba kailangan palitan kung ipa convert ko sa R134 ang aircon ng auto ko? at magkano kaya ang gastos dito?
    TIA
    #273
    Betz: Please do a search, may mahabang thread na about that.
    #274
    Quote Originally Posted by johnart
    Yung magnetic clutch ko nasira din after sustained high speed travel. Hindi kaya yung pag-engage-disengage ng compressor while being spun by the engine at high speeds ang salarin?
    theveed,
    Tanggal freon niyan. Baba ang compressor, eh. Pero hindi Calsonic pinagawa ko nun.
    Mar 2003
    #275
    may magagawa pa kaya si mang mario para lumamig aircon ng hyundai H100 namin lalo na ngayon na kailangan na mag pa convert to r-134a diba mas mahina daw ito magpalamig.
    Dec 2002
    #276
    otep,
    no idea if high speed is the culprit but I drive more faster with a galant vr and had no whatsoever problems with the magnetic clutch. Maybe its a defect by the nippondenso compressor ? Mit Air sa galant. Baka sa pag off road nababasa
    Feb 2004
    #277
    Ayos to.. punta ako kina Mang Mario sa sabado.. , sira auto ko.. me humuhuni sa compressor. So far ayon sa mga nagpatanungan ko. palit compressor na daw.. around 20k aabutin.. sana mali sila at magawaan ng paraan ni Mang Mario..
    #278
    john: could your belt be slipping at higher RPM speeds?
    May 2005
    #279
    Bosstl: try mo din ang check ang tension ng belt ..baka maluwag na at doon galing ang humuhuni..
    subukan mo paandarin ang buhusan mo ng tubig ang belt pag nawala ang tumunog doon nga sa belt iyon make it sure na belt lang binuhusan mo at di naman masyado marami .mabasa lang ang belt
    #280
    Quote Originally Posted by bosstl
    bubuhayin yan nila mang mario...
    yung akin ginawan talaga ng paraan....
    pero nung talagang bumigay na ang compressor ko... palit na lang ng orig surplus... ok naman. 5k yung gastos lahat2 na, di na ko siningil dun sa unang pag overhaul at freon charging. daming discounts dun. ;)
Aircon Repair: Mario Reyes
