Page 12 of 59 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 1163
    #221
    themann,
    Medyo ingat ka sa trike drivers. Nawalan ako ng tatlong valve stem caps dun (it doesn't take a genius to figure out why tatlo lang ang kinuha).
    Pero generally, under sa 'payroll' ni Mang Mar ang mga iyon because he uses them as parts runners. May mga sira ulong talaga.
    #222
    I need help.I was referred here. May grinding sound (just like plastic) akong naririnig everytime the a/c is on. It disappears pag off ko a/c. Had the car checked sa casa and was told na bearings ng compressor ang problem and that the compressor needs to be replaced for 20K. Any ideas?Suggestions? Di ba pwedeng bearings lang palitan dun? Lamig pa a/c ko. I'm worried na changing it might affect everything else. HELP!!!
    Jun 2005
    #223
    wow! 20k?!?!??! pagawa mo na lang sa reputable aircon shops... try mang mario... baka 2k lang abutin mo at kung malasin, mahal pa ang 2k. heheheh
    Oct 2004
    #224
    Quote Originally Posted by pajakboy
    pwede palitan ang aircon bearing. i've had mine done years ago and it's still working.
    #225
    Ako din madami nang napapalitang compressor bearings (on different vehicles). It's not a very difficult job basta marunong a/c tech.
    May 2005
    #226
    iisa lang ba ang size or bearing number ng mga compressor bearing ng different vehicles (e.g. 6005Z ,6202)
    #227
    Iba-iba. Kay Mang Mar, as per sample basis so kailangan muna katayin yun compressor mo.
    May 2005
    #228
    ^^^ thanks... bro OTEP
    #229
    Sayang...napagawa na kasi at 5K --- surplus nga lang. But thanks for the replies anyway. Now, I have another compressor--sira nga lang. Pwede ko ba pagawa kay Mang Mario yun? Tumatanggap ba sya nung repair ng bearings? Para at least, masira man yung isa, may spare na ako.
    Oct 2004
    #230
    ipaayos mo tapos ibenta mo as surplus din...baka mabawi mo pa ang ginastos mong P5k...
    #231
    Just wanna say thank you for this thread. Took my Surf to Mang Mario and got the aircon fixed. Am a very happy camper, so happy I finally registered in tsikot!
    Aug 2004
    #232
    Quote Originally Posted by jayelgee
    same here, nagpalit ako ng compressor nung nagpagawa ako sa DANKEE sa kapitolyo, ang problema lang daw talaga is yung Shaft Seal, at mahirap ata maghanap.
    minsan dadaan ko may mang Mario para pagawa yung compressor para mabenta ko or spare. ride ko Nissan ECCS
    Aug 2005
    #233
    normal lng ba pag takbo mo at on mo aircon may tumunog at naririnig din to pag nag on a/c ng automatic.. normal po ba ang tunog?
    Oct 2004
    #234
    Quote Originally Posted by allanroy
    kung shaft seal, try the Yellow Pages and call Nissan dealers' parts/supplies dept. ganun din problema nung Starex ko. pinagawa ko kay Danknee and he was able to source the part from a dealer in QC Ave. naman...pag tawag ko sa Hyundai sa Pasong Tamo, meron din sila nung part...mas mura pa...minsan it's a matter of sourcing lang talaga...maliit na gomang part lang yung shaft seal na yun...baka nga pwedeng kumuha na lang sa mga napagtapunan nang compressor eh...
    #235
    finchy, if it's like grinding na sound, I suggest pa-check mo. Ganyan nag-start problem sa akin. Kala ko normal na ingay lang until it got worse. I ended up changing yung compressor ko.
    Aug 2005
    #236
    yep yan nga.. grinding.. tama ka.. ano po ba possibilities nito?
    Feb 2003
    #237
    Nagtanong ako ng labor charge nila for cleaning my Revo, P1.2k na pala singil nila. Anyway mura pa rin. Usually ba pinapalitan na nila ung drier? Pachecheck ko na rin ung expansion valve at pumapalag ung aircon ko pag nirerev ung makina. Sabi nung napagtanungan ko baka daw expansion valve na din. May nakapagpalit na ba ng expansion valve/drier kay Mang Mario? How much kaya aabutin para alam kong magdala ng enough cash. Thanks for anybody who can advice me.
    Aug 2003
    #238
    yun din ang problem ng a/c ko yung shaft seal... yun kasi ang sabi ng technician... meron kayang nabibili na shaft seal lang?? ride ko crv 2000 model slamat
    Sep 2005
    #239
    Mga doods! kung shaft seal problema nyo meron si mang mario nyan! yung sa kotse ng erpats ko na galant 79 model, ayaw na tanggapin nung mga pinagdalhan kong aircon repair shop, nahanapan ni mang mario ung sa inyo pa kaya na mga bagong modelo... maraming contact na suppliers si mang mar kaya no need to worry pagdating sa pyesa ng aircon ng sasakyan....
    Oct 2005
    #240
    mga bro, ano loc n mang mario magkno kya pa cleaning ng a/c pajero s knya... tnx
Aircon Repair: Mario Reyes
