Results 11 to 20 of 22
- 54,206
May 29th, 2016 09:05 PM #11
May 29th, 2016 09:18 PM #12
- Jun 2009
- 98
May 31st, 2016 10:52 AM #13thanks sa mgaadvice... got a "bnew" daw blower all together..sa ibang shop. 2700, kasama kabit...
- 54,206
May 31st, 2016 10:57 AM #14
- Jun 2009
- 98
June 1st, 2016 06:14 PM #16
- 54,206
June 1st, 2016 09:15 PM #17perhaps the motor bushings were already ground useless.
when run at low speed, the armature barely turned, and no air was pushed out.
when run at higher setting, the larger oomph caused the armature to turn faster, pushing more air, giving the semblance that it was functioning ok.
that being the case, motor replacement is the solution.Last edited by dr. d; June 1st, 2016 at 09:19 PM.
- Jan 2014
- 186
June 2nd, 2016 07:19 PM #18I also have a problem with my aircon fan, ngayon maingay na sya na dinig mo kahit nka bukas ung radyo sa oto. Ano kya need gawin dto mga paps? Thanks.
- 54,206
June 3rd, 2016 10:15 AM #19sigurado kayong sa aircon fan sa loob ng dashboard ang ingay, ha...? hindi sa aux fan sa harap ng makina.. or sa compressor... or maluwag lang ang fan belt...?
baka may sumasayad.
kung minsan, ito ay dahil may bumagsak sa loob at sumasayad sa rotating parts.
minsan naman, yung moving part mismo ang sumasayad sa "cage" niya. kailangan ng alignment or replacement, siguro.
pa-tingin nyo po sa shop. hindi naman mahal magpa-tanggal ng foreign object, or re-alignment...
medyo mas mataas kung replacement...
good luck.
- Jan 2014
- 186
June 3rd, 2016 03:31 PM #20
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
