Results 11 to 20 of 174
- Apr 2010
- 742
February 23rd, 2013 12:07 PM #11I was the one who wanted to replace both hoses and fittings na lang since alam mo naman when they convert JDM vehicles, typical cut and weld, hanging freely yung suction hose near my turbo (also a year ago I had a hard time steering the vehicle, the pipe interfered with the steering gearbox
) , while my discharge hose ay nakaharang sa air filter ko and when I move it, may hissing sound which I suspect is freon.
I'd still have it tested for leaks first. Yun nga lang kahit 2kms away lang ako from Evangelista eh walang oras to have it checked. Siguro pag pumasok na ang summer months at nabwisit na ako eh dun ko pa lang ipapaaayos :D
Request muna ako opinions from other shops
- 54,298
February 23rd, 2013 12:35 PM #13
- Apr 2010
- 742
March 5th, 2013 12:31 PM #14Finally napagawa ko na, replaced discharge hose and fittings, top up ng freon, replace ng aux fan relays (gumagana na ulit yung dalawa) sa suking mekaniko. php1.1k cost
- Nov 2010
- 24
April 30th, 2013 07:08 PM #15
~ 13 year old honda CRV 2.0 liter. exactly ganoon ang symptoms. It all happened one day when biglang walang lamig. busy ako so pina ayos ko sa relative ko na amatuer mechanic. pumunta sya sa local aircon repair shop owned by his friend. butas evaporator. new evaporator + freon + labor cost 6000. symptoms like the above happened after ma ayos.
so since humina ang aircon after ma replace ang evaporator I assume na either maliit/low quality made in china ang evaporator or maybe somethings wrong with the freon. magkano kaya ayusin ito, using a good quality evaporator?
- Apr 2010
- 742
May 1st, 2013 05:21 PM #16
- Nov 2010
- 24
May 2nd, 2013 05:43 PM #17
- Apr 2010
- 742
May 2nd, 2013 07:48 PM #19Nagpa cleaning ako kahapon, binalik sakin ng malamig (no. 1 na lang sa gabi kasi lumamig ng husto, dati no.2 pa) and medyo lumakas ang blower. Kaninang umaga, tinanggal ko yung resistor block(?) sa evaporator para macheck kung pinull down nga talaga nila (actually iniwan ko lang yung sasakyan, kasi may minor latero works pa), and malinis naman evaporator. Umalis ako ng mga 8am to MOA. Pagbalik ko ng mga 11am, may nakita na akong tubig dripping from the evap, i dismissed it as normal, pero yung lamig ng aircon humina ng husto, until halos mapuno na yung passenger floor mat. Pinacheck ko ulit sa kanila and barado daw yung drain, halos mapuno na yung evaporator, and nung nilinis yung drain hose eh sobrang lamig na tubig yung lumabas.
May dapat pa bang ireplace dito? kasi nung umalis ako ng shop (after declogging the drain hose) eh hindi pa rin masyado malamig, or nagkataon lang na sobrang init kaninang tanghali? Tignan ko tomorrow morning if ganun pa rin yung lamig nya.
May 3rd, 2013 01:21 PM #20
mga sir ganun dn ung liteace ko pag tanghaling tapat hindi lumalamig ung buga pero pag hapon o kaya umaga e sobrang lamig naman, madalas mag automatic na mamatay ung compresor pag umaga o kaya hapon pero pag tanghaling tapat never na mag automatic na mamatay, kakapalit lang dn ung rear evaporator,
sa tingin niyo po mga sir kulang lang po kaya ng freon ?
VinFast VF 3
