^ Thanks for the tip bro. Nakita ko nga iyan sa diy store. Balikan ko na lang
The dissolvable tablet washer fluid seems to test out great. Very cheap and does appear to clean better than just plain water. I use a gallon of filtered drinking water to dissolve one tablet.
https://www.lazada.com.ph/products/p...137267129.html
Is this what you were pertaining to? I've always been curious about this.
https://ph.shp.ee/ftse3eL
The one in the link above looks exactly the same. Link is from Shopee. I bought 6 tabs. Hope it's the same.
I can attest that these tablet types don't leave any marks nor is it harsh on the washer system. I drop one tablet in a 1-gallon jug of filtered drinking water for about 20-30 minutes. It sizzles like Alka-Seltzer while turning the water blue until none of the tablet remains.
I mentioned before that I tried the "Rivers windshield washer fluid" and it caused the one-way valve to clog up (caused the rubber inside to swell and the spring to corrode).
Good to know nito, maka order nga.
Paubos na yung windshield washer fluids sa mga units ko.
Yung stock na wiper fluid ng Suzuki ko, parang may "Rain X" properties ata. Napapansin ko if I use the spray nozzles, later parang nag-bebead & roll off yung droplets pag umulan. Ewan ko lang
