Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
    Jan 2019
    #61
    You can always dilute naman removers with drinking water or distilled. Spray on mf towel then rubby dub.. then buff with damp towel to remove the "acid"
    Dyed tints might get damaged? Not sure..
    Yun nga worry ko sir, baka masira tint. Hehe.
    Try ko muna linisin small area to check.
    Aug 2017
    #62
    Quote Originally Posted by atbondoc View Post
    Hi i have tried Elevo and Mr Squeaky Watermark removal but to no avail. any suggestion po?
    Mr squeaky is very effective in my experience. Although it becomes tedious on heavy watermarks, it does the job. Maybe you are not doing it correctly?
    #63
    Quote Originally Posted by Ronpascual View Post
    Mga sir, what if sa loob ng tsikot yong marks/spots, yong sa tint mismo, puwede pa malinis?
    you can try removing it with plain water first. if it don't work, try using the usual commercial preparations or household medicine cabinet rubbing alcohol..
    read carefully the bewares. some of these things may react with the tint's materials. try it out first at a "sacrificial area", in case it proves disfiguring.
    if nothing works, you can always replace the tint film. heh heh.
Acid rain removal and glass protection tutorial
