Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 101 to 120 of 159
    #101
    Dito ko nabasa sir na magpinsan sila.
    Opinyon | PilStarNgayon Mobile
    Aug 2008
    #102
    Heard on the news:
    Sobra daw minamalas ang NAIA3, kaya nirekomenda na kay Honrado na ipa-FengShui ito para maalis ang malas.
    I kid you not.
    #103
    Quote Originally Posted by leonleon View Post
    Heard on the news:
    I kid you not.
    Please tell me this is a joke.
    #104
    Heard on the news:
    I kid you not.
    so if the fung shooer says the airport is wrongly placed, and that it should be rotated 90 degrees...??
    With election day just around the corner, I pity the candidate running on the "ituloy ang Daan na Matuwid" platform...
    Jan 2003
    #106
    Heard on the news:
    I kid you not.
    We all know masang pilipino lang ang minamalas hangang nakapwesto ang mga dakilang tanga Abnoy, Honrado at Abaya. Tagalin lang sa pwesto mga yan, all will be well. Looking forward for noon of June 30,2016, feel's like liberation day.
    #107
    Feng sui? Kalokohan yan.
    Yung stretch nga ng edsa pina bless-an ni Tule yan nung panahon nya sa MMDA. Ilang drum ng holy water ang winisik dyan.
    Gumanda ba lagay EDSA?
    #108
    Quote Originally Posted by macsd View Post
    Who did you vote for ba in 2010?
    Nov 2007
    #109
    Kahit I-feng shui or paliguan ng holy water ang mga tsuper ng jeep, bus, taxis or even private motorists, wala pa rin magbabago. Pero kapag hulihin ng MMDA or ng pulis dahil sa tottong traffic violations at pagbayarin ng 1k and up na fine, titino mga yan.
    Jan 2003
    #110
    Cyempre GORDON.
    Flight delays, diversions or outright cancellations due to radar outages in RPLL but affecting ALL PH airports... good luck and mahabang pasensya for those who'll be coming back from their vacations. Both cargo and passenger flights are affected
    All flights avoiding PH airspace
    LIST: Cancelled, diverted flights due to NAIA 'technical issues' on New Year's Day
    #112
    I heard AIS is offline daw kaya even other airports can't be used.
    Sep 2010
    #113
    Dry run for Tsaynis invasion. [emoji16]
    Budget na nman yan for overhaul/upgrade.screenshot_2023-01-01-18-51-05-195_com.android.chrome.jpg
    Flights have somewhat resumed pero at the rate of one arrival every 10 minutes... considering almost 300 flight backlogged.
    Earlier at NAIA
    #115
    #116
    ... power supply?
    i'm no electronics person, but isn't that the easiest part of the system?
    Jan 2016
    #117
    2 UPS, 1 Voltage regulator fail and an outdated system, really wow
    Jul 2004
    Jan 2009
    #119
    I'm interested to find out what kind of UPS they were using. For something that is classified as critical infrastructure, I'm sure they're the online double-conversion types. But I can't understand how a failed fan/blower took down everything. These UPSs have bypass modes.... which should address any internal faults that may have developed within the UPS.
    Instead of receiving 240 volts, which is the standard, the system received 380 volts. This destroyed crucial equipment called very small aperture terminals (VSAT), which receive satellite data used by planes and air traffic management systems.
    Getting 380V instead of 220-240V is a wiring and/or possibly a configuration issue, not a power surge. Most large datacenter UPSs are 3-phase. So it would seem that while they were panic-stricken trying to put everything back online, they powered the 220-240V equipment directly from 380V, which is one of the standard Line-to-Line voltage of a 220V/380V 3-phase source. You get 220V from Line-to-Neutral, in this case.
    I think they're playing the blame game to minimize their own failures, pointing a finger at Meralco for the "power surge". If that were actually the case, it would've affected everyone in the neighborhood, not just CAAP.
    #120
    Ang main reason is technical incompetence.
    Most likely naka holiday break yung mga trained technicians.
Power outage hits NAIA Terminal 3
