Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 159
    5 oras? Sobra naman yan.
    Anyare sa backup?
    "Unaccepatable" is an understatement for this situation.
    Oh baka naman praktis yan para sa Election Day?
    Congrats PAbaya, Honrado, et. al., di pa rin kayo patatasikin.
    Palpak pa more.
    Parang mas worse pa ang T3 kesa T1 I can't imagine 5hrs na walang power yon nga may power napakainit na sa loob lahat ng passenger pawisan lalo na mga 3PM pag palubog na araw sakto sa depature
    Sino magiging scapegoat dito?
    5-HOUR AIRPORT POWER OUTAGE
    One generator set at NAIA-3 failed —DOTC chief
    Published April 3, 2016 2:43pm
    A drained generator set probably due to poor maintenance was one of the reasons of the five-hour power outage at the Ninoy Aquino International Airport Terminal 3 (NAIA-3) that left hundreds of passengers stranded.
    "Sabi niya may na-drain [na battery]. Hindi nagkick-in ang isang genset (generator set) natin. May drainage sa battery power... Hindi nag-transmit ng power sa building (NAIA-3) mismo," Transportation and Communications Secretary Joseph Emilio Abaya told radio dzBB in an interview on Sunday morning, referring to NAIA-3 manager Octavio Lina.
    Abaya said that there were 10 gensets at the NAIA-3 and that the other nine worked.
    "Batteries ang pinapaliwanag sa atin kung bakit hindi nagkick-in to the switch gears," he added.
    Abaya said that there is a possibility that the gensets were not properly maintained.
    "I have to check... Tinitingnan natin if it was fully drained, there was no charing prior to this, it was charged but did not switch...," the transportation secretary said, enumerating possible reasons why the genset failed.
    He said that airport officials failed to immediately determine the real cause of the power outage because their priority was to restore power so that operations would resume.
    The blackout at the NAIA-3 happened at past 8 a.m. and power was fully restored at past 2 a.m., Abaya said.
    The NAIA-3's operations were fully restored before noon Sunday, based on an advisory by the Manila International Airport Authority on its Facebook account.
    The MIAA said the power outage at the NAIA-3 happened after a substation of the Manila Electric Company (Meralco) at around 8:45 p.m. Saturday.
    Meralco, meanwhile, said that the glitch was restored in less than a minute.
    It said that the five-hour power outage could have been caused by "trouble on the customer's loadside."
    More than 100 flights were canceled and delayed following the power outage.
    Heads will roll?
    Asked if "heads will roll" over the rare power outage, Abaya said their priority was to restore the operations of the NAIA-3.
    "Alamin natin kung ano ang tunay na dahilan para hindi maulit muli... Ang 'heads will roll' madali na po iyan," he said.
    Meanwhile, Abaya said that he will order the full checking of all gensets at the NAIA and other big airport nationwide.
    “If the problem is maintenance, then we have to check not only in Manila but dapat tignan muli ang maintenance procedures ng airport nationwide,” he said.
    Security and safety
    Civil Aviation Authority of the Philippines (CAAP) spokesperson Eric Apolonio, meanwhile, said that procedures are in place for similar emergencies to assure the safety of passengers.
    Apolinio said the airlines were immediately informed of the situation through their communications tower.
    “Kapag nagkaroon ng power glitch, automatic po ‘yan na advised ang mga airline na umiikot to go on hold muna,” he said.
    Apolinio explained that the separation time between the arriving and departing airplanes from airlines had to be prolonged.
    A report by the Philippine News Agency said some flights that were supposed to land on the NAIA-3 were diverted to the other NAIA terminals (1, 2 and 4) that were not affected by the outage.
    Apolinio assured no violations of the safety procedures were committed during the power outage.
    “Inspite na kulang ang power sa nasabing terminal ay nakalapag naman at nakaalis ang mga airlines although medyo na-delay,” he said.
    He also reminded the passengers of the cancelled and delayed flights of their claims as inscribed by the Air Passenger Bill of Rights.
    “Protektado naman ang mga pasahero diyan. Kaya wala po silang dapat ipag-alala. Ang mga airlines po ay i-a-assist sila,” he said.
    Meanwhile, Apolonio said that standby gensets would naturally fail in case a whole terminal is hit by a blackout.
    “Kapag standy gensets talaga ang ginagamit, mediyo mahina talaga ang binibigay na kuryente at apektado ang security process screening. Ang NAIA ang laki-laki niyan, malaki ang equipment,” he said. —Kiersnerr Gerwin Tacadena/ALG, GMA News
    - See more at: One generator set at NAIA-3 failed —DOTC chief | News | GMA News Online
    So yung battery nung isang gen set na-drain yung power, whic is used to crank up the 9 working gen sets, tama ba?
    Malas lang.....
    Halatang walang nagro-routine maint sa mga gen sets ng T3.
    what i don't believe is the lack of a backup power source. airport yan eh. the backup source should ensure that take-offs, landings and loading and unloading of passengers are not affected.
    dapat dyan tinawag na lang si john mcclaine para makita ang reason.
    Onli In Da Pilipins!
    Singhot pa more!
    29.2K _/_/_/_/_/_/_/_/_/_/
    Quote Originally Posted by NightRock View Post
    Yan din naisip ko. I better avoid all airlines in T3
    Power generation is a critical element of an airport operation!
    Kung 9/10 na gen-sets ang pwede bakit inabot ng 5 hrs ang outage. Something is not right definitely sa kanyang power generation system and besides bakit wala bang black start gen-sets in case the standby units don't kicks in?
    malabo pa ring mag-resign o masibak si abaya & honrado. Bff ng Daang Matuwid.
    Sep 2013
    Kung 9/10 na gen-sets ang pwede bakit inabot ng 5 hrs ang outage. Something is not right definitely sa kanyang power generation system ?
    may mga ilan namumuno sa ating government officials di muna nag-iisip ng tamang dahilan para kahit papano i-misinform sana ang public. ang tingin nila satin t*ng* pero sa tanong mong yan sila ang mas or should I say pinaka t*ng*
    aftermath
    Just waiting for Glenn manikis to post. [emoji16]
    Si Glenn na dapat mag supply ng generator sa T3
    Baka sya ang supplier ng t3 genset🙊🙊🙊🙊
    Paktay.....
    Pinapatawag na ni BS Aquino si Honrado sa Palasyo. Let's see kung ano mangyayari.
    Jan 2003
    Paktay.....
    Laro daw sila PS4, may bagong game si Panot.
    Paktay.....
    Bakit kailangang ipatawag pa?
    He should go directly to Honrado's office and check the situation personally. Bring experts too.
    Discussion in the palace will give the opportunity for Honrado to feed him with sh!t. Is he used to it?
    Go where the sh!t is and get immersed with/in it!....
    Apr 2012
    Buti di nangako si Pnoy magpasagasa sa eroplano pag magka aberya ang NAIA 😂
    Sent from my LG-H818 using Tapatalk
    This is pnoy's opportunity to shine by firing abaya and Honrado and turn the tide in favor of Roxas. Unless of course he has a secret candidate.
    Jan 2003
    Nag file na ng resignation ang mga inutil na Honrado at Abala effective June 30,2016. Put*ng In* talaga sa kapal!
Power outage hits NAIA Terminal 3
