Results 1 to 6 of 6
February 10th, 2007 08:29 PM #1
Mga Bro. please help me naman.. kc recently i've observed that my car needs a sixth gear.. means is there any 6-speed transmission avail for my car with a 2L engine 2.4 liters. just because when im on fifth gear having a speed of 140km/hr its like dat nanhihingi pa ng sixth gear ung makina..
il be waiting for your best and wisest advice.. Thank You Very Much
- May 2006
- 913
February 10th, 2007 08:45 PM #2i dnt think there is one available for your car with sixth gear.. i thnk you can always change the differential ratios..... to a higher ratio...
February 10th, 2007 08:50 PM #3
feeling lang mo po yan... 5 is enough na sa revo mo....ko nga 4-a/t on my 2c-te liteace is enough na...
- Jan 2007
- 66
February 10th, 2007 11:58 PM #4oo nga.. imposible naman yun,, sa revo may six gear?? hehe.. kung gusto mo 6 gear buy ka na lang ng sports car.. opinyon ko lang yun ha..
- Oct 2004
- 278
February 11th, 2007 01:18 AM #5What for? Do you know that Toyota 5-speed ans 6-speed transmissions have their ratios almost equal sa last gear?
For example: Toyota V160 transmission (yun lang ang nasa isip kong RWD 6speed ng Toyota eh)...
Gear ratios from 1st to 6th: 3.830 2.360 1.680 1.310 1.000 0.790
Di ko sure kung ano ang tranny ng Revo diesel, but if yung Toyota G52 sya:
Gear ratios from 1st to 5th: 3.930 2.330 1.191 1.00 0.830
Difference: 0.040
%diffrence (0.830 to 0.790) = 4.82% <-- do you think 4.82% increase on your top speed is worth the trouble?
Conclusion: More gears does not always mean so much higher top speed - higher accelaration sure yan...
Good luck din if you can get yourself a 6-speed RWD transmission to match your bell housing/engine block.... If you find one, please tell me where...
If you would like higher top speed talaga, change the differential ratio.... mas practical and less hassle... Your stock is 4.3:1 if i'm not mistaken. You can try looking for 4.1:1 or 3.909:1...
Another option: Swap your engine to the one on your avatar/username (3S-GTE).... you'll be a very happy man...
February 11th, 2007 05:14 PM #6
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
