Results 1 to 6 of 6
February 10th, 2007 08:29 PM #1
Mga Bro. please help me naman.. kc recently i've observed that my car needs a sixth gear.. means is there any 6-speed transmission avail for my car with a 2L engine 2.4 liters. just because when im on fifth gear having a speed of 140km/hr its like dat nanhihingi pa ng sixth gear ung makina..
il be waiting for your best and wisest advice.. Thank You Very Much
- May 2006
- 913
February 10th, 2007 08:45 PM #2i dnt think there is one available for your car with sixth gear.. i thnk you can always change the differential ratios..... to a higher ratio...
February 10th, 2007 08:50 PM #3
feeling lang mo po yan... 5 is enough na sa revo mo....ko nga 4-a/t on my 2c-te liteace is enough na...
- Jan 2007
- 66
February 10th, 2007 11:58 PM #4oo nga.. imposible naman yun,, sa revo may six gear?? hehe.. kung gusto mo 6 gear buy ka na lang ng sports car.. opinyon ko lang yun ha..
- Oct 2004
- 278
February 11th, 2007 01:18 AM #5What for? Do you know that Toyota 5-speed ans 6-speed transmissions have their ratios almost equal sa last gear?
For example: Toyota V160 transmission (yun lang ang nasa isip kong RWD 6speed ng Toyota eh)...
Gear ratios from 1st to 6th: 3.830 2.360 1.680 1.310 1.000 0.790
Di ko sure kung ano ang tranny ng Revo diesel, but if yung Toyota G52 sya:
Gear ratios from 1st to 5th: 3.930 2.330 1.191 1.00 0.830
Difference: 0.040
%diffrence (0.830 to 0.790) = 4.82% <-- do you think 4.82% increase on your top speed is worth the trouble?
Conclusion: More gears does not always mean so much higher top speed - higher accelaration sure yan...
Good luck din if you can get yourself a 6-speed RWD transmission to match your bell housing/engine block.... If you find one, please tell me where...
If you would like higher top speed talaga, change the differential ratio.... mas practical and less hassle...Your stock is 4.3:1 if i'm not mistaken. You can try looking for 4.1:1 or 3.909:1...
Another option: Swap your engine to the one on your avatar/username (3S-GTE).... you'll be a very happy man...
February 11th, 2007 05:14 PM #6
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
