Results 11 to 18 of 18
BANNED BANNED BANNED
- Aug 2007
- 999
April 8th, 2008 11:06 PM #11Nagawa na yung car ko.....grabe may leak pala yung AT.....Nilagyan ng sealant....observe ko....
Mukhang na-drain talaga ng maayos...... inabot ng 7 liters atf....6 liters na hindi pa lumilevel doon "hot" sa dipstick....
Pero bakit pag binaliktad yung dipstick eh lagpas na sa level....pero walang 'hot" na word pag binaliktad....
Kasi di ba ang dipstick ng engine eh kahit baliktaran malalaman mo kung nasa level.....pero sa atf meron word na hot...pero sa kabilang side wala na.....
Hindi kaya na-over pag lagay sa akin....kasi usually nababasa ko pag atf di ba six liters lang....pero sa akin umabot ng 7 liters......eh Lancer ito...
April 8th, 2008 11:18 PM #12
sir suv, i do hope that you were following the procedure for how to check your ATF level... it's in the manual. if you check it incorrectly your level could be lower than necessary or higher... now 7 liters of ATF is a lot. i just changed the ATF of my mom's car( lancer) it came out 6. something. and that is with a completely drained tranny...
- Aug 2007
- 999
April 8th, 2008 11:39 PM #13^
Kasi nung 6 liters wala pa rin sa level.....nung 7 doon lang umabot....di ba pang naka- D yun ang tamang pag sukat ng ATF?
Na drain talaga yung sa akin....flushing talaga.....
PEro if ever na sumobra yung sa akin eh bad ba yun? Tapos yung last bottle ng atf ko eh ibang brang ng atf ginamit.... yung first six eh same brand....ok din ba lang yun?
April 8th, 2008 11:46 PM #14
sir suv, uhmmmm ganito kasi yun, ideally when you check your atf level engine should be warm, i'e running for more than 15 minutes na. what you do is with the engine running engage your hand brake, stepp on the brake pedal ang cycle through all the levels of your transmission lever stopping for a few seconds on each level(P, stop, R, stop, N, stop, D, stop, 1, stop, 2, stop, 1, stop, D, stop, N) always check ATF with the shifter on Neutral!!! now if you have a gate transmission iba ang routine dun, yun ang hindi ko alam, pero pag straight lang siya, yung sinaba ko ang gagawin dapat(as per manuals)
regarding the ATF mixing, hindi siya sir advisable, pero nandiyan na eh.... next time na lang uli. same thing with oils, as much as possible don't mix and match.
hope this helps...sorry kung gumulo lalo gabi ninyo!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 9th, 2008 12:56 AM #15just have a shop with an atf exchanger do it for you. it shouldn't be that hard naman and that the only way to really clean all of the fluid.
- May 2004
- 903
- Nov 2003
- 3,849
April 13th, 2008 04:20 AM #17we have one in the shop. there are also other who may have it but i don't have a listing of who does.
April 19th, 2008 06:37 AM #18
Sir SUV, better siguro check this tips regarding auto transmission kompleto ng tips dito even yun replacing ng torque converter filter http://www.carcare.org/Auto_Transmis...to_trans.shtml
Good Day
personally, my more pressing concern would be the price of the car...
Shares of Toyota, Mazda, Honda and Suzuki fall...
