Results 1 to 18 of 18
    Aug 2007
    Di ba sa loob ng transmission ito? So kailangan pa ibaba yan....Mahal yung labor....
    May 2007
    Quote Originally Posted by suv View Post
    yup and can't do anything on 'coz sealed yun. so di ko alam kung ano ang gagawin ng mekaniko mo dun.
    kung talagang torque converter ang problem pinapalitan na lang yun. may mga surplus nyan.
    Aug 2007
    Hindi naman sira....
    Nabasa ko lang dito na sabi "dont forget to drain the torque converter" pag atf change
    Eh paano pala madedrain yun?
    kung maintenance issue lang, nde na kailangan i drain yung torque converter. Pero kung gusto mo,pwede, You have to have to drop the trans. Or kung gusto mo na malinis talaga ipa trans flush mo.
    Jan 2008
    removing the torque converter from the automatic transmission is not advisable and may cause leaks and serious damage!! when changing ATF just DRAIN the transmission on its DRAIN PLUG.. no need to dismantle the transmission from the engine just to drain the torque converter.. there are shops offering ATF change using machines to thoroughly remove the old ATF...
    even when buying a SURPLUS automatic transmission like in BANAWE.. always choose the transmission that have its TORQUE converter attached to the tranmission.. even mechanics when pulling down transmission from surplus engines they make sure that the torque converter will not be separated from the transmission..
    Aug 2007
    Saan shops dito sa araneta or banaue may machine sa pag drain ng ATF?
    Yung machine ba na gamit nila eh yung bobombahan ng hangin?
    Sa casa sabi sa akin ng mechaniko ang technique daw nila para daw ma-drain din yung atf sa torque converter eh yung connection daw sa radiator hose and transmission tapos papaandarin daw.... Hindi ko kasi masyado magets yung sinabi pero yun daw technique nila... Ok ba yung techinique na yun?
Torque Converter- kailangan bang linisin?
