do this happen after you step on the brakes while on "D"? when you push the accelerate pedal again, it does not run anymore?
if it is, you could be running out of ATF...
most ATF measurements should be car running on "P" then measure your ATF...
happened to me when I based my measurements on turned off engine...
though better check manual for sure...
