Results 1 to 10 of 22
Tsikot Member Rank 3
- 400
November 17th, 2002 09:24 PM #1I've just noticd lately that shifting gears on
my manual transmission 96 Civic is not that
smooth anymore as it used to be.
Parang "soggy" ang feeling, parang maluwag
ang pasok ng cambio.
What could be the problem?
- 83
November 17th, 2002 11:10 PM #2hindi naman sliding? meron pin lock yan shifter...magpa machine shop ka lang ng bago kse dapat dya "Force-fit" inquire ka sa local shops... SMT did mine. good luck!:wink:
- 400
November 18th, 2002 10:11 PM #3Hindi naman sliding. It doesn't nga lang fit as good as it used to...
November 20th, 2002 12:18 PM #4
Try to have your gear oil level checked or better have it changed. I hope this helps. Goodluck.
November 20th, 2002 08:26 PM #5
gear oil check o check mo yung turnilyo sa ilalim sa tabi ng muffler baka lumuwag na kay di ganon ka accurate madali makita yon higpitan mo lang it happened to me once dahil nababad sa baha at kinalawang kaya lumuwag.
just sprayed wd-40 tapos hinigpitan ko ak na ulit.
- 237
December 31st, 2002 11:16 PM #6bat po ganun...
nakapgpalit na ko ng clutch disc,plate
change tranny oil na rin....
bat sumasabit pa rin ung pag shift ko?
nu po kaya problem?
yebo8 GuestJanuary 1st, 2003 08:45 AM #7
Questions muna:
1. Properly adjusted ba clutch mo - kung hydraulic, na-bleed na ba ng husto? kung cable, tama ba adjustment?
2. Sure ka ba na tama apak mo sa clutch?
3. Does it happen sa particular gear or pair of gear lang, say 1st/2nd gear or 3rd/4th gear lang sya sumasabit?
If your answer is YES - YES - YES...
...malamang worn out na yun synchronizer gear and synchronizer keys pare ko. That means your tranny needs to be opened for overhaul. Expect to spend anywhere from 3k to 10k, depende kung complete or partial overhaul gagawin mo.
aray ko po!
- 237
January 1st, 2003 01:48 PM #8hmmm....lets see....usually sa 1st gear 2nd gear lang....
hmm....nableed?not really sure...il ask our familiy mechanic...siya ksi tumira nun...
tama apak sa clutch?yep...minsan nga tlgang inaapak ko na ng husto para pasok eh....
yebo8 GuestJanuary 1st, 2003 04:58 PM #9
sayang, nagpalit ka na pala ng clutch disk sana napa-open mo na rin yun trannny mo para isang trabaho na lang ano. synchronizer gear and synchronizer keys (3 each per gear set yun). baka pati yun shifter yoke pudpod na rin siguro. palitan mo na rin bearings para minsanan na pare. well, syempre depende sa budget mo.
January 2nd, 2003 10:02 AM #10
looks like we have a "tranny guru" in the making here. What can you say Otep?
Roadstar is reliable.
Finding the Best Tire for You
