Results 11 to 20 of 57
- Oct 2005
- 51
November 7th, 2005 08:52 PM #11ano ba usually madaling masira o madaling palitan pag A/T ang car? tuwing kelan pinapalitan
November 7th, 2005 08:56 PM #12
mas matagal ang service interval ng automatic transmissions. yung manual transmission kasi depende minsan sa driving style ng driver, minsan mabilis mapudpod yung clutch disc. yung A/T kasi fluid type sya and electronically controlled ang shifting kaya kahit pano mo apakan ang accelerator, nasa mood parin ng A/T system mo ang pagshift.
Signature
- Oct 2005
- 51
November 7th, 2005 09:02 PM #13anong RPM ba usually nagshift ang A/T pag normal drive? Pag nakapatay ang OD anong RPM nagshift?
November 7th, 2005 09:08 PM #14
O/D means 4th gear (for 4-speed transmissions) or 5th gear (for 5-speed transmissions. O/D is normally turned ON. if you turn off O/D, your transmission will only shift up to 3rd gear (for 4-speed transmissions) or 4th gear (for 5-speed transmissions).
shifting point for A/Ts depends on how hard you step on your accelerator pedal, the harder your step on it, the higher the shifting point.Signature
- Oct 2005
- 51
November 7th, 2005 09:22 PM #15ok tnx.. sana madali lang idrive yung automatic hindi ko pa kasi natry tnx
November 7th, 2005 09:28 PM #16
madali lang talaga magdrive ng automatic, para ka lang naglalaro ng video game na racing
Signature
November 8th, 2005 12:11 AM #17
thanks guys. i know P locks up the transmission so i'm a bit confused which is better to use at the time parked and idling. at a red light, yup i use N if i think the waiting time(stationary) would be at least around 3 mins, otherwise i leave it at D.
magilos dali lang i-drive A/T, having came from a manual transmission myself. di mo na aalalahanin shifting gears at tapak sa clutch. you'll see pag nakuha mo na car mo. at nasa manual din ng kotse how to drive yong automatic transmission. search ka rin dito sa thread about info on A/T.
- Oct 2005
- 51
November 8th, 2005 12:20 AM #18tnx din sa mga reply nyo tanong ko na lang ako sa inyo pag may problema about A/T sana ngayon week makuha ko na yung A/T na sasakyan namin.. Tnx
November 8th, 2005 02:01 AM #19
Ako nung una kala ko hindi ko kaya magdrive ng a/t pero nung dumating ang picanto namin na a/t dun ako natuto at nalaman ko madali lang pala gumamit ng matic.Ang ayoko lang sa matic medyo delay ako sa reaction ko at pag stop and go ang traffic timpalahan sa pagtapak ng gas..
November 8th, 2005 02:20 AM #20
"N" and the parking brake are the best combo for traffic lights. For waiting for periods longer that that, engaging the parking brake and shifting to "P" is good.
But NEVER use "P" to hold the vehicle still. That's what the parking brake is for. Unless you want a VERY expensive parking brake.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
