Just to answer this question, leave it off and you can go as fast as you want in top gear (or as fast as the car/environment permits). However, if you turn it off, the car shifts to a lower gear. Then you should know what the maximum speed the car can reach at that gear. If you're not sure then don't push it, turn the overdrive on and let it upshift to protect the engine/transmission from damage.
