Results 1 to 10 of 45
    Nov 2007
    mga kuya anu po ba dapat pag nag ddrive ng automatic car & van lagi ba dapat naka on ang over drive??
    para saan ang hold button???
    ngayon lang ulit kasi ako nakapag drive ng matic ,btw kia pregio ang van ko
    Sep 2004
    Overdrive allows the engine to run at a lower rpm for a given road speed, resulting in better fuel economy (ideal for cruising speeds). So whenever possible, engage overdrive when driving your A/T vehicle, except when overtaking, going uphill or downhill (engine braking) since OD mode reduces engine torque.
    In manual transmission vehicles, the highest forward gear is the overdrive gear.
    Nov 2007
    thanks sir btw: it means na mas makakatipid ako sa diesel pag laging naka over drive ang van ko?
    Sep 2004
    In normal driving conditions, makakatipid ka kung laging engaged ang O/D mo. However, you should still consult your owner's manual for the proper speed on which to run on overdrive.
    Nov 2007
    kung sa inyo po ano ba ang pwedng top speed for automatic O.D is ON sa kia pregio?
    Jun 2006
    AFAIK, OD should be on all the time. Except as previously mentioned, overtaking, uphill and engine braking. It is the highest gear on your AT. I think the pregio is a 3 speed AT. OD is your 4th gear.
over drive & hold  button para saan?
