Results 1 to 10 of 12
October 19th, 2008 11:38 PM #1
nasobrahan ko ng lagay ng automatic transmission fluid ung honda ESI ko. masama po ba ito?pano magbawas ng atf na nailagay ko. kasi dun ako usually naglalagay sa lalagyan mismo ng dipstick.
October 20th, 2008 12:37 PM #2
Yes it's bad it can cause your AT to overheat if it has tto much. You can drain it using the drain plug if your AT has one.
October 20th, 2008 12:50 PM #3
yup if your ATF has a drain drain from there. otherwise, pull the hose going to the radiator, drain, salukin mo nalang yung atf w/clean bottle then balik mo yung hose.
run your engine, dont shift! just leave it sa P. after 10 sec off mo. dapat * engine running temp na ha for more accurate reading sa dip stick.
punuin mo muna halfway between the low and full marks. run the engine for 1 minute. (dont shift sa P lang) then measure ulit. pag same pwesto parin between low and full, dagdagan mo up to 3/4 the space between low and full. run the engine then repeat this until steady na sa full mark.
wag ka mag-overfill! unlike sa makina, pag AT ay punong puno ng fulid, malulunod/mabibilaukan yan.kung baga sa tao-- uminom ka ng sobrang daming tubig, diba feeling bloated ka.
and always remember, not all atfs are the same, follow whats indicated on the manual!
sa dipstick hole talaga lagayan ng atf.
- 299
October 21st, 2008 10:08 AM #4buy ka nung pang siphon ng liquid sa iyong suking supermarket. piliin mo yung may small diameter na tube. ipasok one end sa pasukan ng atf, then squeeze mo na lang palabas sa another container. happened to me before.
BANNED BANNED BANNED
- Jul 2003
- 2,267
October 21st, 2008 12:42 PM #5just drain the excess oil using the drain plug. esi has a drain plug in its tranny.
anyway, how did you measure your atf level?
for me, normal operating temperature while engine is running as what the repair manual says.
- Sep 2008
- 1,219
October 22nd, 2008 02:18 PM #7
so does it mean at cold engine ung measurement sa dipstick ng atf is more compared pag uminit na ung makina which is parang bumababa ang measurement sa dipstick pag mainit na?
- Jul 2003
- 2,267
October 22nd, 2008 02:57 PM #8parang ganun n nga ayon sa aking obserbasyon.
dati kasi may problema ako sa shifting kahit na ok naman level ng atf. yun pala mali yung paraan ng pagmeasure ko kasi pag malamig ang makina ko ginagawa. masakit din kasi pag dumait yung braso sa mga mainit na hose eh hehehehe
tapos yun, nabasa ko dapat normal engine temp. nagdagdag ako. ngayon slipping ang 3rd gear ko. baka dahil dun sa low atf ko na akala ko ay tama.
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 16th, 2008 12:47 PM #9pag sobra just have it drained. if di mo alam papano then have someone do it for you.
- Jul 2003
- 2,267
November 17th, 2008 11:43 AM #10
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
