Results 1 to 10 of 30
- Feb 2013
- 42
March 19th, 2014 11:17 AM #1HELLO,mga katsikots magtanung uli ako sa inyo kung normal ba sa automatic transmission na pag nakapark ka sa medyo inclined o matarik tapos pag abante ka sa drive na hindi mo masyado diin selenyador o parang alalay lang ay aatras pa yung sasakyan ko bago aabante.akala ko kasi pag naka D ka ay hindi aatras.minsan kasi may nakatutuk sa likod ko noong nakapark kami sa inclined na kalsada nang aabantre ako ay muntik mabunggo cya buti nadiinan ko agad selenyador kaya yun umabante agad.mga 30degrees inclined yung kalsada nagparkan namin.salamat sa inputs.
March 19th, 2014 11:26 AM #2
dapat hindi,
habang apak mo ang preno and ilagay mo sa D, walang galaw dapat yan.
March 19th, 2014 01:17 PM #3
Ganyan sa vios ko pag masyado matarik. Kaya brake muna bago tanggal sa park then quickly switch your foot to gas.
Posted via Tsikot Mobile App
March 19th, 2014 01:35 PM #4
With most conventional A/T, there's a slight lag from the time you shifted to Drive and the gears/torque converter engaging. Keep your foot on the brakes until you feel the car starting to lurch forward.
On a very steep incline with the engine at idle, it may not have enough power to keep the car from rolling backwards. In this case, you have two options to keep the car from rolling backwards:
1. Use the brakes as a pseudo clutch. With your left foot firmly on the brakes, apply some gas with your right while releasing the brakes slowly. Remember to do this very gently to prevent the car from surging forward
2. Use the handbrake method as you would in a manual transmission
March 19th, 2014 04:20 PM #7
If the idle speed is too low or the engine is misfiring there is a tendency for a car with A/T to roll backwards when going uphill from standing still even in D range
Nakiki wi-fi lang
- Aug 2012
- 2,767
March 19th, 2014 04:49 PM #8kahit naman sa M/T if matarik ang daan.. aatras ang sasakyan if galing sa hinto at kulang tapak sa gas. matarik na yang 30 degree..
March 19th, 2014 05:34 PM #9
- Jan 2013
- 143
Ano kayang problema kapag iyong digital odometer display Ng kotse hindi agad namamatay after I...
0dometer problem
