dextron3 is backwards compatible with other dextron types.
gear ff is for lsd equipped transmission. kung hindi naka lsd yan just use gear 300.
correct me if i 'm wrong pero ang lsd o limited slip differential kasi is kapag naka-lift parehas ang both drive wheels, kapag inikot mo yung isa sa isang direction, sabay yung kabilang gulong. unlike sa hindi limited slip differential na kapag inikot mo yung isang gulong sa isang direction, yung kabilang gulong baliktad sa ikot nang pinapa-ikot mong gulong.![]()
Tama is sir ian_rex.
LSD is a traction aiding device. Unless your model had an LSD equipped variant, chances are you have a [conventional] open diff.
mga ilang liters and manual transmission oil for a 97 cefiro? i want to try motul. any feedbacks about this gear oil?
about 2.5-3 liters of the gear oil for the cefiro. i assume it's manual right?
a member of tsikot loaded up with motul gear 300 kanina on his galant. let's wait for his feedback![]()
tnx. tnx.
ok ba 2?
[SIZE=1][/SIZE] [SIZE=1]
[/SIZE] [SIZE=1]
[/SIZE] [SIZE=1][/SIZE] [SIZE=1]
[/SIZE] [SIZE=1]
[/SIZE]
ang nakalagay sa manual ay API GL-4, SAE 75W/85w
ano ibig sabihin ng sae 75w/85w?
tia po.
that's the viscosity. gear 300 is 75w90 tho but it should do the trick naman.
Besides on Motul, anu pa bang gas stations offers a better 75w90 gear oil? Na-try ko kasi Shell eh, ok rin ba Caltex? Anyone tried? Any good feedbacks you can give peeps? TNX!![]()
apno po ba malalaman kung kelan ka na dapat magpalit ng gear oil for a 97 manual tranny cefiro?
tia
^^ its the same as engine oil, you have to replace that at a certain interval.
meron na rin RP gear oil for M/T, syncromax yata yun name I used it last year and shifting is really smoother
Hi , i just changed my gear oil yesterday, i drained it then pour 2.5 lit of thuban trans oil on that hole for the speedometer, then put back the speedometer, did i do the right thing ???
, will the trans oil goes down to the tranny and axle as well ??? my car is 1993 Nissan JX, tnx
synchromax is for honda's. for most other cars the max gear will do. this is normally replaced every 40k kms.
there should be a filler plug for the tranny. pour there and stop pouring when umaapaw na. if you pour into the speed sensor hole you might overfill it.
Hi sir,
How about for 1995 toyota corolla (4AFE) what kind of oil will I use/buy for its manual transmission and how many Liters it will consume.
Thanks...
check your owner's manual. manual transmissions vary and the oil recommended by the transmission manufacturer vary. some manual transmissions use automatic transmission fluid, most use extreme pressure lubricant, just check the owner's manual and stop guessing
