Results 1 to 10 of 18
September 1st, 2005 06:31 PM #1
Just wondering coz i just had mine totally removed and replaced with a new silicone oil. I used GMB and was able to fill 5 vials, as in nag-umapaw. Then napansin ko na parang palagi nalang naka-engaged ang fan ko. What could be wrong? Hindi kaya pangit na brand ang gamit ko? or sumobra lang sa silicone oil?
September 1st, 2005 11:33 PM #4
Wait for afrasay or you could PM him directly. Kabisado nya yan, ilang sasakyan nya ang nalagyan na ng silicon oil.
September 2nd, 2005 05:14 PM #5
Originally Posted by ravelcop
September 2nd, 2005 05:34 PM #6
AFAIK, the silicone oil is the main agent inside the fan clutch that promotes the engagement of the fan on high temperature. When your vehicle's temperature is cooler, the silicone oil is soft, propeller turns on a freewheel manner. At high temperature, silicone oil hardens, causing the fan to grip so it goes along at the same speed with the engine's rpm. So the higher your rev is, the faster the fan turns. You would notice it coz it produces a vacuum cleaner-like noise. So basically, as the silicone oil hardens during high temp, the fan engages otherwise, the oil softens in cold temperature and the fan dis-engages.
September 2nd, 2005 05:38 PM #7
ung clutch fan kasi is mostly sa mga rear-drive vehicles...ung nakatapat sa radiator na umiikot kasama ng makina...freewheeling un para daw di mag-drag ung engine..
ung oil is for the moving parts inside that fan...
ask ko lang mga sirs, anu po oil ung?san nabibili at tuwing kelan pinapalitan?
thanx!
September 2nd, 2005 06:23 PM #8
silicone oil tawag dun, it is sold in vials. mga P65 ang isa. pinapalitan pag notice mo na parang hindi na masyadong kumakagat ang fan mo during engagement. Or if your vehicle tends to overheat, that's one of the things you must check.
problema ko is, i dont know kung how many vials needed to totally replace the silicone oil in the fan clutch. kasi mukhang nasobrahan yata yung sakin eh, kasi palagi nalang naka-engage ang fan kahit malamig ang engine temp. ang ingay. siguro wala nang magalawan ang mga moving parts inside the fan clutch dahil punung-puno na ng oil
September 2nd, 2005 06:32 PM #9
ask ko lang din po, panu po pinapalitan? panu po matetest kung "engaged" ung clutch fan?
sorry, ha, kasi my father, sinusumpa ung free-wheeling na clutchfan, kay pinafix nya ung sa old delica ko...(siyempre sulsol ng mga mekaniko-mekanikohan)...now kasi my ride is a liteace 2c-t ang makina, e good namang di fixed ung clutch fan...
kasi habang under repair, isasabay ko na din ito...
thanx!
September 2nd, 2005 06:47 PM #10
yan palagi remedyo ng mga mekaniko, kase tamad sila maghanap ng real cause. pag naka-fix kase, kawawa ang engine at fan mo dahil palaging naka engaged, tapos matagal pa mag warm up. resulta, poor fuel efficiency at maingay.
binubuksan lang yung fan clutch, split it into two then lagyan mo yun ng silicone oil. mahirap pag sealed type coz hindi pwedeng buksan, kelangan palitan talaga ng bago ang whole clutch. malalaman mo na engaged na ang fan when it reaches the certain temp, mga 40-50%, then the fan starts to turn producing loud noise pag ni-rev mo. tapos tatahimik ulit sya pag baba ng temp
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
