Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 81
    #61
    Quote Originally Posted by SoleusBB View Post
    Prob is, traffic eh!
    By the way, wag din tumutok sa mga FX & UV express vans. Minsan yung mga kamoteng pasahero sa likod, walang pakialam mag open ng rear hatch.
    tama isa pa yang mga hayop na yan
    Sep 2006
    #62
    Quote Originally Posted by chronicle View Post
    Nakakainis talaga yung mga naka lagay sa park (based on how the reverse light briefly turns up), pag sa stoplight ang bagal umarangkada kasi kelangan pa ishift.
    And most of the time, titingin sa shifter kung tama ba. So unsafe kasi for a brief moment, you take your eyes off the road. Eh kung may bata na biglang tumawid na mahirap mapansin since maliit?
    Andami ganito bro. Diko alam kung ano trip nila o kung sino pontio pilato nag turo ng ganun
    Oct 2007
    #63
    It's not only in the Philippines, I'm sure other parts of the globe some driver is also doing that.
    #64
    Quote Originally Posted by Luiscachero View Post
    I don't get some drivers who put their cars on Park during traffic or on a stoplight???? From D, ilalagay all the way to P then ibabalik to D pag uusad na. I noticed this kasi nakikita ko nagbblink yung reverse lights nila, meaning na dumaan sa Reverse yung shifter.
    What I do pag traffic or sa stoplight more than 1 minute, I put it on N, pull up the hand-brake in order to cause unnecessary wear sa brakes
    when one puts it on P, the car stops moving, even without the brake pedal. driver does not have to have to go to the trouble of activating his hand brake.
    normally naman kasi, no harm is done with this maneuver.
    I don’t trust the handbrake bro, mura lang naman ang bumbilya [emoji23]
    Swerte yung ibang equipped with e-hold ba yun?
    My cx-5 has pero dun pa rin ako sa neutral and apak brake /handbrake... la pa ako tiwala sa auto hold... hahaha...
    Feb 2019
    #66
    I'm not sure if this is the right thread for this question, but anyway, please enlighten me on this: Yung parking area namin dito is naka-elevate so pag nagpapark kami, we have to control the car properly kasi uphill yung pagpasok. May instances na backing ako magpark, then one time habang nagrereverse ako sa uphill, bigla kong nabitawan yung brake which caused the car to move forward. My question is, is that okay? Meron bang possibility na ma-damage yung transmission ng oto ko or what so ever? If that so, any advise or meron bang proper way to do that and vice versa? Advisable din po bang tapakan ang brake while pressing gas pedal then slightly release the brake pedal to move? Thanks in advance!
    Aug 2017
    #67
    Quote Originally Posted by jnsk View Post
    Instead of using the brake pedal, use the hand brake
    Feb 2019
    #68
    Quote Originally Posted by SidCoronel View Post
    Is that okay even if its CVT?
    #69
    no harm will come to the transmission, or the engine, po.
    transmission slip is normal in AT or CVT cars.
    you'll run out of right feet, if you press on the gas pedal and the brake pedal at the same time. it just ain't practical. i agree with sid: use the handbrake.
    and you will eventually notice, using the handbrake in instances like this, is easier if the handbrake is adjusted according to spec.
    Feb 2019
    #70
    I see. How about using hand break, ano po pwede maging prob nito sa katagalan kung ganun yung gagawin?
    #71
    just like the pedal brakes, the brake shoes wear out faster, if one uses the handbrake often.
    but the wear is so miniscule, hindi mo mapupuna. it is practically a non-issue.
    the handbrake mechanism is also expected to endure more wear and tear.
    but it's no big deal, as they are doing what they were designed to do.
    Aug 2017
    #72
    Shouldn't be a problem. MTs uses this all the time when "hanging" on traffic to avoid burning the clutch . You did drive a manual yes?
    Feb 2019
    #73
    While reversing in uphill, pull handbrake to stop the car rolling forward, then slowly release it while pressing the gas pedal to reverse completely. Is that correct?
    #74
    yes .. makakasanayan mo rin yan
    Aug 2017
    #75
    Brake pedal to full stop... Then lift the hand brake.... Then release the brake pedal.. A little throttle... Release hand brake.
    Always use the brake pedal to stop.
    Feb 2019
    #76
    Copy, thanks sa advice mga paps! [emoji4]
    Jan 2020
    #77
    Hi! noob here sa A/T cars. How about pag running uphill then nasa D ako and pag na notice ko nag-struggle/hirap yung engine, what i did was to shift it directly to a lower gear say D-3 ba yun or 3? any harm on the tranny? what is the best practice sa ganong situation? Tapos kapag naka-ahon na sa uphill, i switched it again to D.
    Sep 2005
    #78
    just release the gas pedal when changing gears.
    Quote Originally Posted by rai_23 View Post
    Revving up doesnt mean hirap ang engine. The sound of toyotas and hondas above 4000rpm is good.
    If you're slowly losing speed just step on the accelerator more, it will automatically drop a gear. If you step on it too hard it will drop 2 gears( medyo mabigat paa mo and more fuel is needed/consumed)
    Jan 2020
    #80
    yes sir qwerty, ni-release ko yung gas pedal while shifting to lower gear and vice-versa.
    oo nga sir stockengine, losing speed might be the proper term.
    so i guessed no harm was done to the tranny. thanks for answering
How to properly drive an automatic transmission car during traffic?
