Results 1 to 20 of 81
    Jan 2020
    Hi! noob here sa A/T cars. How about pag running uphill then nasa D ako and pag na notice ko nag-struggle/hirap yung engine, what i did was to shift it directly to a lower gear say D-3 ba yun or 3? any harm on the tranny? what is the best practice sa ganong situation? Tapos kapag naka-ahon na sa uphill, i switched it again to D.
    Sep 2005
    just release the gas pedal when changing gears.
    Quote Originally Posted by rai_23 View Post
    Revving up doesnt mean hirap ang engine. The sound of toyotas and hondas above 4000rpm is good.
    If you're slowly losing speed just step on the accelerator more, it will automatically drop a gear. If you step on it too hard it will drop 2 gears( medyo mabigat paa mo and more fuel is needed/consumed)
    Jan 2020
    yes sir qwerty, ni-release ko yung gas pedal while shifting to lower gear and vice-versa.
    oo nga sir stockengine, losing speed might be the proper term.
    so i guessed no harm was done to the tranny. thanks for answering
    Mar 2018
    Sa matic ng Ertiga it has an O/D switch. I just push that whenever I see a consistent uphill road is ahead just like Kennon Road. In your case, you can easily switch to D-3.
How to properly drive an automatic transmission car during traffic?
