Results 11 to 11 of 11
Threaded View
- Aug 2005
- 183
April 27th, 2016 01:37 PM #1Guys, need some advice regarding our 2003 Honda Crv automatic transmission. The problem is when the car slows down and downshifts to 1st gear from a higher gear, there is a jolt or shift shock. While accelerating, I noticed some noise when the tranny shifts from 1st to 2nd gear. Last year, I had an atf dialysis but using castrol transmax instead of honda atf. I brought it to our suking mechanic. He told me that this won't be solved by simple transmission overhaul. May mga clearances na daw kase. Replace transmission na daw eto. Any advise on what to do? Thinking of another dialysis using honda atf muna. By the way, the odometer reading of our Crv is already at 156000 km.
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
