Results 1 to 11 of 11
    Aug 2005
    Guys, need some advice regarding our 2003 Honda Crv automatic transmission. The problem is when the car slows down and downshifts to 1st gear from a higher gear, there is a jolt or shift shock. While accelerating, I noticed some noise when the tranny shifts from 1st to 2nd gear. Last year, I had an atf dialysis but using castrol transmax instead of honda atf. I brought it to our suking mechanic. He told me that this won't be solved by simple transmission overhaul. May mga clearances na daw kase. Replace transmission na daw eto. Any advise on what to do? Thinking of another dialysis using honda atf muna. By the way, the odometer reading of our Crv is already at 156000 km.
    Kelan nagsimula magka-ganyan?
    Quote Originally Posted by r_delro View Post
    Honda uses their own proprietary fluids (ATF, CVTF, PSF) and their older AT trannies are quite picky with fluids. Not using such fluids may damage the tranny or power steering system. For older Honda cars, ATF change is usually done every 40k KM. Older Honda CVT cars require even shorter gaps (20k KM). Not being mindful of the fluid change schedule will not be good in the long term.
    If you live near Cavite area, I suggest you go seek out Mel Casaba. He is quite well known among owners of Honda AT cars here in Tsikot. Seek out his opinion or any other mechanic who is quite well versed with the picky nature of Honda AT trannies.
    Below is the thread about Mel Casaba in the Honda forum:
    Honda specialist: Mel Casaba Back in Cavite with his new shop
    Aug 2005
    2 weeks na ata sir...yung atf dialysis ko was done last august lang. Sabi dun sa castrol transmax compatible with honda atf-z1...
    If quezon city ka go to kaizen west avenue sanay pag honda yan. Parang bodega yung shop nya puro surplus.
    Pero ask mo muna opinion kung marerepair pa. Wag ka payag na palit transmission agad. Kasi business nya magparating ng honda surplus. Pero magaling yun may-ari jan. Sinasabi ko pa lang symptoms alam na nya.
    Example sa meron ingay sa engine sa ibang talyer gusto palit agad tensioner bearing. Pero sa kanya sa experience nya with honda civic 6th gen eh nakatatlo palit ka na timing belt eh ayos pa tensioner. Pero syempre hindi mo papaabutin ng ganun katagal tensioner. Sabay dapat sa timing belt or sa 2nd change ng timing belt.
    Aug 2005
    thanks for the reply...will give him a visit soon...buti na lang medyo malapit sa amin....i'm from las pinas pala...
    How many times have you changed your ATF when you got your hands on the car? It would be best if you can tell Mel Casaba a maintenance history of your CRV.
    for a second opinion you can bring your crv to danny of d&r fast auto repair service along sucat ave in paranaque
    kumpleto gamit nila at dyan dinadala ng honda makati ang mga tranny na for outsource servicing nila. actually magsasawa ka kakatingin ng mga tranny of all makes and sizes na ginagawa nila (ford, honda, hyundai, toyota, etc). iyon nga lang agahan mo punta kasi ang daming customers
    Oks dito kina Danny (D&R Fast Auto Sucat). Eto yung suki kong shop kung saan mini-maintain yung dati kong Accord at iba pang Honda cars namin. Madali kausap yang si Danny.
    Dito si Mel Casaba dati kina Danny bago nagtayo si Mel ng sarili nyang shop sa Cavite.
    Apr 2008
    Bro kamusta na yung tranny mo? napaayos mo na ba? ano naging problem? Same kasi tayo ng symptoms.
    Aug 2005
    Revive this thread lang...nagblink na yung d habang umaandar and the tranny jolts especially during reverse...pa repair kn...will update this thread on any developments
Honda Crv A/T problems
