Results 1 to 10 of 41
October 15th, 2006 10:18 PM #1
I have an everest a/t and just today parang nagloloko siya. On a flat road pag nag reverse ok naman siya pero pag nilagay sa drive ayaw umabante, even when i step on the accelerator. I thought at first stuck up na naman ang preno like 2 weeks ago. Pero nung nilagay ko uli sa reverse normal naman pag atras.Mga 3 or 4 times kong ginawa ito (forward-reverse pero each time ayaw talaga umabante)finally on the 5th time umabante na, hindi naman uli nangyari itong incident. what could be wrong? imposible namang stock up brakes kasi pag naka reverse umaatras without any problems.Kumakagat rin naman ang drive kasi nafefeel mong nag engage ang gear.
October 15th, 2006 10:23 PM #2
Posibleng yung detent dun sa mismong shifter ay hindi pumantay dun sa detent dun sa mismong transmission [it is connected by a series of rods and other thingamajigs]. So kahit dun sa detent mo sa shifter ay 'D' na, baka hindi pa talaga umabot dun sa setting na 'D' dun sa mismong transmission. Sana sinubukan mo 'lumampas' ng 'D' [e.g. going to '2' or '1']. This can be adjusted if it is persistent.
Iyon kasi nangyari sakin sa Starex. Naka-D na pero ayaw umabante. Hindi ko naman na pina-adjust. Bihirang-bihira lang naman mangyari (siguro 2x pa lang).
October 15th, 2006 11:18 PM #3
sir otep,
hindi ko nasubukan ilagay sa 2 or 1. Pero pag lagay sa D may naramdaman naman akong shift shock na parang aabante. when i released the brakes hindi nag creep ang i applied gas para umandar(umabante pero a few inches lang siguro), yung feeling na parang may kalso mga gulong kaya ayaw umabante. Nag try ako mag reverse to another area to test it at ganun parin.First time lang nangyari ito pero sunod sunod naman. Nung umabante na hindi na naulit kaso im worried na baka may nasira sa transmission
October 15th, 2006 11:52 PM #4
When was the last time your change the trans oil?Maybe it's time to drop the pan and look for metal particles.
October 16th, 2006 12:56 AM #5
havent changed the at oil yet. 36k na on the odo, does it have to be changed this early? by the way, does anybody know how much atf is needed for the everest atf change?and what brand do other owners use
October 16th, 2006 05:53 AM #6
yeah its too early to change at 36k but if you're having a problem with your trans i guess draining and filling your trans oil(no flushing since it's only 36k) and checking the pan for metal particles is a good insurance.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2003
- 32
October 16th, 2006 03:55 PM #8anyone know a good mechanic for automatic transmission? my opel omega is having some problems. i know that it uses the same transmission as some bimmers - 4L30E.
thanks.
October 16th, 2006 04:22 PM #9
Try this first, shift mo sa "2" or any gear lower sa D, does it move? If so, baka shifter bushing lang yan like mine...
Check out my thread a few months (or last year ata hehe)
http://tsikot.yehey.com/forums/showthread.php?t=21889
October 16th, 2006 08:00 PM #10
My Dongfeng Nanobox - a case study of an electric...
