Results 11 to 20 of 57
August 11th, 2019 08:12 PM #11
Guys, pasingit lang. Normal ba na parang maluwag yung hand brake pag nakababa? I mean may 1-2cm syang naangat na parang lose? Or kelangan ipacheck?
Also, before starting engine, oks lang bang magshift from P to N then saka iistart? Vice versa pag papatayin yung engine. Thanks!
- 52,731
August 11th, 2019 08:26 PM #12hand brakes need adjustment from time to time, to take up the slack caused by brake pad wear and cable stretch.
sometimes, the lever itself is worn from age...
if your car allows for moving the stick from P to N before starting, then so be it. you just lose the extra protection of the P brake, in case you forgot to put on your handbrake.
some cars will not normally allow such movement from P to N, until after the engine starts.
August 11th, 2019 08:33 PM #13
Kakakuha ko lang ng oto ko 4 days ago eh. Napansin ko lang kanina parang maluwag sya, pero oks naman pag inaangat. Mahigpit pa. Pag nakababa lang parang nawiwiggle up and down.
Yes, binasa ko kasi yung manual nya, sabi need to shift from P to N before starting engine. Nashishift naman sya as long as naka ON yung keys.
August 11th, 2019 08:39 PM #15
- 52,731
August 11th, 2019 08:39 PM #16pa-adjust nyo.
mura lang yan.
i am not on banawe's payroll, but...
if it is not inconvenient to you, drive there and let them boys have a go at it. they do it all the time. they already know the wrench sizes and screwdriver types needed for the job.
errr... what car na, po?
- 52,731
August 11th, 2019 08:41 PM #17
August 11th, 2019 08:43 PM #18
- 52,731
August 11th, 2019 08:44 PM #19brand new cars should be perfect, upon delivery.
but we are all human.
i guess that is what warranty is for.
my owner's manual says that the brakes should bite with two to three clicks.
good luck, po.
- Aug 2017
- 294
August 11th, 2019 09:30 PM #20
Monk-owned R53
