Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
    Jul 2018
    #21
    ouch bro! sana pink pa ang atf.. otherwise fluid nga..
    Thank you, Sir!
    Aug 2018
    #22
    Quote Originally Posted by shelu View Post
    mine is 2007 crosswind xuv a/t... tranny seems to be slipping, medyo mataas na ang rpm, mabagal pa ang takbo.. ang ginawa ko, nagpadialysis atf change hoping mag improve ang takbo.. nakaubos ng 18 liters ng atf at im sure malinis na ang nasa loob at marumi din talaga ang nailabas, parang kulay putik na.. ito ngayon, lumala pa ang takbo after dialysis.. halos di ko na maiuwi sa bahay dahil hirap na pag paahon... sliding talaga.. sa flat roads, makatakbo pa... any suggestions mga sir? sakit na ulo ko dito... magkano kaya rebuilt ng tranny ng crosswind? may surplus kaya pang crosswind?
    Sent from my SM-G610Y using Tapatalk
    Same experience sa akin, Dinala ko sa casa. Solenoid Lang ang pinalitan 7k Ang parts at 7k ang labor. Pero 2 weeks cla nag diagnosed bago Nila na solved.
    Nasira daw young 2nd gear na solenoid kaya ang tagal bago mag shift nang 3rd gear.
    Feb 2009
    #23
    Quote Originally Posted by res2cebu View Post
    That's an awfully long diagnosis. Hope they didn't charge you for all that time. They probably found the problem by guessing and hoping and they got lucky finally
    mukhang ginamit muna nila. hehehe
    Jan 2010
    #25
    Sir the same po ang problem ko with my 2005 crosswind XUVi millage 85K ginawa ko na rin yung pagpalit ng langis sa drain pan pati filter hinugasan na bakit po nag da drag pa rin sya posible po ba na solinoid or or transmission na pls advise po. Thank u so much
    Sep 2008
    #26
    Quote Originally Posted by Carla paj View Post
    Rebuild is around 30k, parts and labor, I have a good trusted mechanic and shop that does it.
    Rebuilt mine last July 2020; the quote was P38k however there was additional part replaced and added P10k or total of P48k; After the rebuilt it was noticeable that the reverse would take too long before it engage. However if first started on a day the Reverse would engage outright.
    Jun 2011
    #27
    Dito kayo nagpapagawa ng AT, or may ibang suki?:
    Automatic Transmission Specialist
    Sep 2008
    #28
    Quote Originally Posted by bxr monkey View Post
    Hindi, sa Kirsten Autoworks, 1625 Blumentritt Road, Sampaloc, Manila
    Jun 2011
    #29
    Quote Originally Posted by onrac View Post
    Mahal din pala mag overhaul ng AT.
    Baka okay ipa check ulit kay Kirsten ang reverse. Labas pag cold okay, pag hot na AT fluid may delay. Possible kaya may air bubbles sa reverse line?
Crosswind a/t slipping
