Results 1 to 4 of 4
    Dec 2008
    Please recommend which transmission oil for manual transmission nowadays. Which one have you tried and tested very good. Is Toyota m/t transmission oil good?
    Our car is BAIC m20 2017 m/t.
    Thank you.
    Jun 2005
    Quote Originally Posted by louiellopez View Post
    Thank you.
    Id probably starte by reading the manual, getting the required oil specs, check which is available in the market then decide.
    Always start with the viscosity the manufacturer requires.
    Sent from my MI MAX 2 using Tapatalk
    Which fluid is recommended in the owners manual? Im curious if these chinese vehicles also copy the japanese&american standards.
    Jul 2013
    ^I agree, check the manual
    Some manufacturers may state the oil should last the car's lifetime (which basically means 150,000miles)
    sa totoo lang, sa dinaming M/T na sasakyan na dumaan sa amin, never kong naalala na nagpalit kami ng (manual) transmission fluid (pati differential fluid, di kami nagpalit)
Which oil for manual transmission do you recommend
