we've pretty good experience with the seiken brand din. better than fic (?).
Yung FCC ba eh same with OEM..whats the difference?
How can I know that its orig? newbiee kasi ako dito
I have a sliding clutch kasi..I plan to have it fixed ASAP
Thanks
sir fcc po gamit ko yung nagpalit ako ng clutch... eto po yung recommend ng motor craft sakin yung sliding na clutch ko.
ok naman po.. its in a blue box. dapat sealed pa din ito pagbili mo.
edit: ok yung pagpalit ng clutch ko... parang wala na ko inaapakan sa sobrang lambot. :clap:
yeah, the seikens last much longer nga. more expensive too but sulit in the long run.
Pag di na kaya ng cable adjustment, malamang upod na ang loob nyan. kapapalit ko lang last saturday ng clutch system ko ganyan din problema hard shifting at maingay pag neutral (pero nawawala when you press the pedal).Kailangan ko bang palitan yung clutch system ko kapag medyo mahirap ikambyo, esp. kapag mag-shift ka from 2nd to 1st gear and vice versa?
Super swabe na ngayon, konting pitik lang ayos na. Replacement parts lang for the plate and disk, original yung release bearing(mas mura kasi sa replacement??).
question lang kung ano ba signs and symptoms na malapit na masira clutch? 2 and 7 months na rin before nasiraan kuya ko at napaayos.. sa ngayon wala pa naman na maingay at di naman ako nahihirapan sa clutch. 40 kms/day average lang nito. minimal traffic lang. dito kami gen.trias cavite at malayo sa traffic ng bacoor at imus.
ano ba signs and symptoms??...![]()
most of the bigger auto supplies will have. lalo na if they specialize in higher quality parts. the clutch alignment tool mahihirapan ka to buy... mostly shops lang meron who either make their own or order it from abroad.
Bakit po kung minsan nahihirapan ako magpasok sa first gear kung minsan naman madali. Sa first gear lang naman po. Kapapalit ko lang ng clutch. Sabi sakin baka sa timing lang ng pagtapak sa clutch at change ng gear kaya lang bakit dati di ko naman napapansin na mahirap at sa first gear lang nangyayari? tia po sa reply.
try adjusting the free play of the pedal. it might work. maybe the gear oil too if di pa nagagawa.
seiken is a good replacement. i didn't know they have aluminum and steel types for their clutch assys.
ako oem pinalit ko...bought it from tQa but have it installed sa reffered mechanic ng tiyuhin kong tiyuper... imagine: more or less P20K worth of parts and labor sa casa tapus a week or more nila sstock ung altis ko dun?
buy na lang the orig oem ones then have it install sa most trusted shop or mechanic mu
good day good luck sa ride mo![]()
pre i recommend you buy EXEDY-DAIKIN performance clutch,its the same brand used sa casa.as always.dapat dun ka sa suki auto parts ka bumili.one set yun:pressure plate,clutch cover,release bearing.yung release bearing.you can buy the brands like KOYO or NSK.
