Results 1 to 20 of 46
    Jul 2005
    Mga bossing
    ok lang ba yung replacement na piyesa for my clutch system (clutch
    cover, pressure plate, release bearing) or should i go casa? ok na
    din ba ang performance/quality ng mga replacement? any feedback sa mga
    naka gamit na ng replacement for their clutch assembly my car is an
    ae111
    Maraming salamat!
    God Bless!!
    based on experience ok ang replacement sa gas engine, wag lang sa diesel. yun ingay ng release bearing ang evident pag replacement ang ginamit mo sa diesel ride. for replacement part buy the popular brands such as asco. ewan ko yun denki kung ok siya.
    Jan 2003
    I've always used OEM pamalit sa clutch disk, pressure plate, etc, so ewan ko kung ok ang replacement.
    The one time I used replacement parts for anything clutch-related was for a master repair kit. Nothing but trouble! Pag mainit na yung makina, tumutukod sya, making the clutch slide. It's like always stepping on your clutch halfway, hindi nga lang nangangawit yung paa mo. Umayos lang when I changed it back to OEM.
    OEM is the best. You don't necessarily have to get it from the CASA if you know what an original part looks like or if you have a trusted parts source.
    Still, there are reputable replacement brands as previously mentioned.
    Aug 2003
    pag ganyan type ng parts papalitan mo, i would suggest getting OEM din para sigurado ka tatagal yung part. hindi masakit sa ulo.
    Aug 2005
    ok lng bro OEM. basta japan ha. di japan2x ..
    Dec 2007
    Yung FCC ba eh same with OEM..whats the difference?
    How can I know that its orig? newbiee kasi ako dito
    I have a sliding clutch kasi..I plan to have it fixed ASAP
    Thanks
    sir fcc po gamit ko yung nagpalit ako ng clutch... eto po yung recommend ng motor craft sakin yung sliding na clutch ko.
    ok naman po.. its in a blue box. dapat sealed pa din ito pagbili mo.
    edit: ok yung pagpalit ng clutch ko... parang wala na ko inaapakan sa sobrang lambot. :clap:
    Nov 2003
    yeah, the seikens last much longer nga. more expensive too but sulit in the long run.
    Quote Originally Posted by speedyfix View Post
    saan nakakabili ng seiken?
    saka, bakit wala akong nakikitang alignment tool na binebenta? di ba talaga uso yun dito sa pinas?
    Nov 2003
    most of the bigger auto supplies will have. lalo na if they specialize in higher quality parts. the clutch alignment tool mahihirapan ka to buy... mostly shops lang meron who either make their own or order it from abroad.
    Apr 2009
    hi .. i have a question. i used Seiken for my clutch master assembly.
    i bought the steel one. meron din aluminum pero mas mahal. sabi sa akin
    matibay daw steel.
    pls give your insights on this...
    salamat.
    Quote Originally Posted by iridescent_1 View Post
    Mga bossing
    ae111
    Maraming salamat!
    God Bless!!
    seiken is a good replacement. i didn't know they have aluminum and steel types for their clutch assys.
    Jan 2009
    aisin brand ng clutch ok ba toh?
    ako oem pinalit ko...bought it from tQa but have it installed sa reffered mechanic ng tiyuhin kong tiyuper... imagine: more or less P20K worth of parts and labor sa casa tapus a week or more nila sstock ung altis ko dun?
    buy na lang the orig oem ones then have it install sa most trusted shop or mechanic mu
    good day good luck sa ride mo
    Jun 2009
    AISIN in the brand used by almost all japanese cars.yan din yung brand na gamit sa casa.i've scouted and have all the info ng brands ng pyesa sa casa.
    Aug 2005
    Na surprise ako to learn na yung Adventure (2002 GLS gas type) ko is
    cable type pala yung clutch.
    Kasi last week hirap ipasok sa ist and reverse gear (with grinding metallic
    sound). Sabi ng mekaniko cable type nga at malapit na raw mapatid.
    It cost me around P750 for the replacement and an hour to replace it.
    Ngayon OK na siya and like brand new swabe na mag change gear.
    Tanong ko lang, all my other cars are hydraulic type, bakit meron palang
    "cable type" - what are the advantage/disadvantage of this clutch type,
    at talaga bang napapatid din siya sa katagalan (in my case seven years).
    What other car models have this "cable type" clutch system.? Alin mas matibay between the two?
clutch question
