Results 21 to 40 of 46
    Nov 2003
    #21
    we've pretty good experience with the seiken brand din. better than fic (?).
    #22
    Quote Originally Posted by speedyfix View Post
    +1 on this.
    Seiken (the ones in the red box) seem to last longer than FIC (the ones in the white box). I've tried both of them on my ex-Pajero.
    Dec 2007
    #23
    Yung FCC ba eh same with OEM..whats the difference?
    How can I know that its orig? newbiee kasi ako dito
    I have a sliding clutch kasi..I plan to have it fixed ASAP
    Thanks
    #24
    sir fcc po gamit ko yung nagpalit ako ng clutch... eto po yung recommend ng motor craft sakin yung sliding na clutch ko.
    ok naman po.. its in a blue box. dapat sealed pa din ito pagbili mo.
    edit: ok yung pagpalit ng clutch ko... parang wala na ko inaapakan sa sobrang lambot. :clap:
    Nov 2003
    #25
    yeah, the seikens last much longer nga. more expensive too but sulit in the long run.
    Jun 2008
    #26
    Quote Originally Posted by Yoda View Post
    The repair kit is applicable only if your clutch is hydraulically activated, eg. doesn't use a cable. Hanapin mo yung clutch fluid reservoir mo, the repair kit is essentially the innards of that assembly.
    I don't think this is a regular maintenance type thing, you replace it when you experience problems like the clutch not disengaging or disengaging fully when you step on the pedal, leaking assembly, etc. My current ride's with me for more than 4 years already, hindi ko pa nagagalaw tong part na to and doesn't look like the previous owner did either.
    The repair kit I was referring to in my earlier post was for a previous ride, a Corolla XL 91. It was P480 back in '99, ewan ko kung magkano na ngayon. Didn't keep track of how much the replacement was, pero mga P250 lang yata.
    Tanong ko lang bro,
    Kailangan ko bang palitan yung clutch system ko kapag medyo mahirap ikambyo, esp. kapag mag-shift ka from 2nd to 1st gear and vice versa?
    Toyota XL 1996 yung tsikot ko. Salamat po.
    Jan 2008
    #27
    Pag di na kaya ng cable adjustment, malamang upod na ang loob nyan. kapapalit ko lang last saturday ng clutch system ko ganyan din problema hard shifting at maingay pag neutral (pero nawawala when you press the pedal).
    Super swabe na ngayon, konting pitik lang ayos na. Replacement parts lang for the plate and disk, original yung release bearing(mas mura kasi sa replacement??).
    Aug 2006
    #28
    question lang kung ano ba signs and symptoms na malapit na masira clutch? 2 and 7 months na rin before nasiraan kuya ko at napaayos.. sa ngayon wala pa naman na maingay at di naman ako nahihirapan sa clutch. 40 kms/day average lang nito. minimal traffic lang. dito kami gen.trias cavite at malayo sa traffic ng bacoor at imus.
    ano ba signs and symptoms??...
    #29
    ^^ symptoms niyan... medyo matigas na clutch and/or maingay na clutch.
    #30
    saan nakakabili ng seiken?
    saka, bakit wala akong nakikitang alignment tool na binebenta? di ba talaga uso yun dito sa pinas?
    Nov 2003
    #31
    most of the bigger auto supplies will have. lalo na if they specialize in higher quality parts. the clutch alignment tool mahihirapan ka to buy... mostly shops lang meron who either make their own or order it from abroad.
    Oct 2008
    #32
    Bakit po kung minsan nahihirapan ako magpasok sa first gear kung minsan naman madali. Sa first gear lang naman po. Kapapalit ko lang ng clutch. Sabi sakin baka sa timing lang ng pagtapak sa clutch at change ng gear kaya lang bakit dati di ko naman napapansin na mahirap at sa first gear lang nangyayari? tia po sa reply.
    Nov 2003
    #33
    try adjusting the free play of the pedal. it might work. maybe the gear oil too if di pa nagagawa.
    Apr 2009
    #34
    hi all ..
    puede singit balikan lang yung seiken clutch master ... i just replaced my clutch master with seiken, ang question ko kasi binili ko yung steel .
    meron din kasing aluminum ng clutch assembly. ano difference ng steel and aluminum? ano mas matibay.
    Jan 2003
    #35
    sir speedy,
    any idea how much will it cost me for the clutch assembly replacement of my 98 civic, granting that i use seiken brand? thanks and God bless.
    Apr 2009
    #36
    hi .. i have a question. i used Seiken for my clutch master assembly.
    i bought the steel one. meron din aluminum pero mas mahal. sabi sa akin
    matibay daw steel.
    pls give your insights on this...
    salamat.
    Quote Originally Posted by iridescent_1 View Post
    Mga bossing
    ok lang ba yung replacement na piyesa for my clutch system (clutch
    cover, pressure plate, release bearing) or should i go casa? ok na
    din ba ang performance/quality ng mga replacement? any feedback sa mga
    naka gamit na ng replacement for their clutch assembly my car is an
    ae111
    Maraming salamat!
    God Bless!!
    #37
    seiken is a good replacement. i didn't know they have aluminum and steel types for their clutch assys.
    Jan 2009
    #38
    aisin brand ng clutch ok ba toh?
    #39
    ako oem pinalit ko...bought it from tQa but have it installed sa reffered mechanic ng tiyuhin kong tiyuper... imagine: more or less P20K worth of parts and labor sa casa tapus a week or more nila sstock ung altis ko dun?
    buy na lang the orig oem ones then have it install sa most trusted shop or mechanic mu
    good day good luck sa ride mo
    Jun 2009
    #40
    pre i recommend you buy EXEDY-DAIKIN performance clutch,its the same brand used sa casa.as always.dapat dun ka sa suki auto parts ka bumili.one set yun:pressure plate,clutch cover,release bearing.yung release bearing.you can buy the brands like KOYO or NSK.
clutch question
