mga sirs,
i already replaced all parts of my L300 diesel but still i cant shift the gear when engine is running but when its off it can shift?
i replace the ff parts:
clutch disc - one the 1 spring is broken but the lining is thick,pero replace ko
pressure plate - kayod narin,kya replace na din
clutch fork - broken push rod returner,yung lang and sira pero pinaltan kona din
release bearing - may tama na din
primary clutch - worn out piston&wheel caps, piston chamber ok pa niliha kolang.
secondary clutch - worn out piston&wheel caps,piston chamber ok pa niliha kolang.
ganun parin ayaw mag shift.
hope help me guys soon.
tia
